It is currently Sun Nov 01, 2026 8:49 pm
Post Posted: Mon Nov 08, 2010 8:45 am
Hi all,
Just picked up a 110amp el/ef alt today and am about to undertake upgrade in my Drover, just wondering if anyone could confirm what water pump I need that will fit the swift pulley but also fit my G13A. I've been looking on ebay and most of the swift water pumps say they are for auto's only, the others look exactly the same as the sierra ones. I've tried searching to no avail, will be grabbing swift water pump pulley and crank pulley tommorrow from wreckers, I just want to make sure I buy the right water pump. If someone could give me an ebay link it would be most appreciated.
Cheers Matt
1985 Holden Drover, soon to be modified
Post Posted: Mon Nov 08, 2010 10:04 am
there was some info in this thread... with me no really knowing the sierra's that well doesn't help that much...
http://auszookers.com/index.php?name=Fo ... ic&t=16341
foolsp33d wrote:
sickzuk1 wrote:
So it may not fit?
the pump itself will fit, its the pully on the shaft that you may have issues with.. but if your upgrading the alternator to a 110amp and changing pullys then this is not of any concern as you can use the swift pully.. but you will need to change the crank pully, at the same time..
Post Posted: Mon Nov 08, 2010 4:33 pm
I used this shop and part when i did mine
http://cgi.ebay.com.au/Suzuki-Swift-Hol ... 3a603abbf0
then go to a wrecker and get the pulley, it's off of a swift that looks the same as the holden barina year model.
Post Posted: Mon Nov 08, 2010 7:15 pm
Cheers for the help guys, I'm hoping I will get to the wreckers today and get the pulleys off a swift I saw yesterday, without the pulleys in my hand I was not sure of bolt spacing, I might email ebay sellers to confirm bolt spacings.
Cheers Matt
Users browsing this forum: Google Adsense [Bot] and 379 guests
