It is currently Thu Jul 30, 2026 3:42 pm
Vehicle: suzuki sierra sj80
Post Posted: Sun Nov 14, 2010 11:07 pm
hey guys just wonted to no how hard it is to put a ga16b motor into a seirra any advice welcome cheers
Post Posted: Sun Nov 14, 2010 11:09 pm
use the search function, there are 900 000 000 threads on this, we dont need another.
Post Posted: Sun Nov 14, 2010 11:14 pm
Help out or refrain from shit replies.
Post Posted: Sun Nov 14, 2010 11:21 pm
I suk at searching via the search button, so I had a look around, have a read of this besides being a ripper build, it also speaks of engines.
Post Posted: Sun Nov 14, 2010 11:24 pm
Just to confirm, by ga16ba, do you acctually mean g16a or g16b?
Cos there's a big difference between the two...
I want my old sig back :(
Post Posted: Sun Nov 14, 2010 11:30 pm
Ben, I have never done it, but arn't they the same in regards the nuts and bolt side, BeT kit, an reposition mounts, thats about it, then all the fancy stuff.
Not too hard at all. U'll need an adapter plate between the engine and gearbox (BenT off this forum makes a nice one). If its a G16 carby engine you will just have to modify the stock 1.3 carby hat to suit. If its the EFI version u'll need a high pressure fuel pump, some high pressure fuel hoses and a bit of wiring work.
Dan
Lil Foot!
Post Posted: Sun Nov 14, 2010 11:32 pm
zookernator did a write up in the tech articles but i can't get to it...
EDIT: found it http://auszookers.com/index.php?name=Fo ... hlight=vss
Post Posted: Sun Nov 14, 2010 11:45 pm
Crikey, I looked for that, how did u find it.
Me and search button hate each other.
Post Posted: Sun Nov 14, 2010 11:53 pm
Don't be a hater, teh search works well, i was sure it was in the tech articles but couldn't get to it or find it so i searched for "g16" & "threads" by "zookernator" knowing the author helps cut it right down to a couple of threads.
Post Posted: Mon Nov 15, 2010 12:00 am
lol knowing the words to use helps a lot, I didnt try the search, as it hates me, but I would have tried something like, g16 into sierra or 1.3 to 1.6 engine swap, whatever, and gotten no results.
Post Posted: Mon Nov 15, 2010 12:03 am
Its all the fancy stuff thats different...
To go EFI you gotta do all the wiring, fuel system etc etc. A lot more work than bolting a carby motor in ;)
Post Posted: Mon Nov 15, 2010 12:04 am
Sometimes more is less, especially if you know that thread exists. really this dribble should be in the Grimbo & the search function thread.
Sorry outram for taking this slightly off topic, have a read thru Zookernators write up & let us know if you need more info. Are you wanting to go EFI or stick with the carby 1.6?
Post Posted: Mon Nov 15, 2010 12:13 am
Another G16B option http://www.auszookers.com/index.php?nam ... 23&start=0
Post Posted: Mon Nov 15, 2010 9:16 am
Kind of on this note, does anyone know if the vit flying wheel is solid steel or cast??
Post Posted: Mon Nov 15, 2010 10:22 am
steel im pretty sure steaky
Vehicle: 85 SJ413
Post Posted: Tue Nov 16, 2010 7:51 am
The ones I have seen are a machined casting, same as the Sierra, and will probably be cast iron, not cast steel.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Tue Nov 16, 2010 7:59 am
Ben
Cheer's.. So lightening's not an option..May have to get one made..
Vehicle: 85 SJ413
Post Posted: Tue Nov 16, 2010 8:11 am
Your not going all ricer on us are you Stekky? Why you want lighter? Usually heavier makes for nicer offroading.
Ben
Post Posted: Tue Nov 16, 2010 8:28 am
Ben
8O F*#k NO!!!!! 8O
Just a theory, I'm getting a vit box to go into Sully & don't want to loose the quick rev's of having the sierra flying wheel on the 1.6 but want the bigger clutch.. :P
Post Posted: Tue Nov 16, 2010 8:36 am
steak_knife wrote:
Ben
8O F*#k NO!!!!! 8O
Do us a favour and weigh the Vit flywheel and the Sierra flywheel. I bet the Vit one is a fackload heavier.
BTW, why can't you machine a cast iron flywheel?
Post Posted: Tue Nov 16, 2010 8:46 am
You can, but if you lighten em to much that explode..just a lil bit. 8O
Users browsing this forum: Google [Bot] and 251 guests
