It is currently Tue Nov 03, 2026 10:14 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
Post Posted: Thu Nov 18, 2010 9:04 am
do it man
twinsticks rule Armsup
Post Posted: Thu Nov 18, 2010 9:57 pm
What about the position of the handbrake and centre console?
Do I need to replace the hubs at the front?
09 Jimny Sierra Limited Edition
Post Posted: Fri Nov 19, 2010 6:18 am
Best to, other wise you'll have to dick around tricking the module to think it's still in control..
Could be wrong but I think the console has been marked out to.. :?
Post Posted: Fri Nov 19, 2010 8:14 am
Sounds expensive...
Post Posted: Fri Nov 19, 2010 9:39 am
do the button transfer's work off air???
Post Posted: Fri Nov 19, 2010 9:55 am
Front hub's do (vaccume), & I'm not about to type out how the frigging stupid figgin control module's work.
I've had to "trick" the module into thinking the transfer was in 4h so I could line up the selector in the transfer, suzuki said I shouldn't of been able to do it.. :roll: What would thay know.. :roll:
Post Posted: Fri Nov 19, 2010 10:21 am
hmm okay
well his problem in with the vac hubs yeah?
or is the solenoid what tells the vac hubs to work?
sorry i'm mostly asking because i'm weird and have to know how things work.....
Post Posted: Fri Nov 19, 2010 10:28 am
:roll:
If he want's to go stick he'll need to get manual hub's, as the module that control's said hub's want's/need's signal's form the shift solenoid on the transfer, it could be set up as a stand alone vacc switch, but man hub's are a lot more reliable than vacc.
The only reason that they have vacc hub's is people are lazy & CBF getting out of the car to lock in..
Which brings the question to mind, how the f*#k do they air down.. :lol: 8O
Post Posted: Fri Nov 19, 2010 10:38 am
well i dont air down every single time i take the shortcut (only shorter in distance but takes longer... but its more fun!) home from work. . .
and yes I am lazy =]
Post Posted: Mon Dec 20, 2010 12:47 pm
grave dig!
will vac hubs, and im guessing the knuckle fit a sierra housing? :D
Post Posted: Mon Dec 20, 2010 8:19 pm
the sierra manual hubs fit a jimny if you make up 5mm spacers to go over the lip that sticks out to seal them so im not sure if they will work properly on a seirra.
Post Posted: Tue Dec 21, 2010 12:38 pm
but does anyone know if it's a bolt on fit? im expecting to have to do some form of hub mod's to sort out the vacume lines but other then that a straight fit?
Users browsing this forum: Google [Bot] and 61 guests
