It is currently Sat Aug 01, 2026 4:56 pm
Post Posted: Fri Nov 19, 2010 7:21 am
how do you get the pins out to get the bush to the bottom ??????
Post Posted: Fri Nov 19, 2010 7:23 am
You don't, just grab the bush & pull...
It will slide out in between the pin's, same thing with fitting the new one..
Post Posted: Fri Nov 19, 2010 7:27 am
there is none left, new one doesnt have any notches to clear the pins. should it... there was two roll pins in the kit i thought they must replace the old ones but f me if i can figure how the come out. they mushroomed over
Post Posted: Fri Nov 19, 2010 7:36 am
Just push the bush past the pin's..
How much of the pin's are left??
Post Posted: Fri Nov 19, 2010 7:37 am
plenty
Post Posted: Fri Nov 19, 2010 7:49 am
benji wrote:
plenty
:P PUSH!! :P
Or get a hammer... :roll: :? 8O
Vehicle: I drive your mum
Post Posted: Fri Nov 19, 2010 8:01 am
With some wiggling you should be able to slip it in there. Well thats what she said anyway :wink: :wink:
Layto....
Post Posted: Fri Nov 19, 2010 8:37 am
Here's my yearly tech :-)
I'd like to add to this with a bit more details.
So many times I have heard people say "Man my t-case is stuck. It's broke. Now what do I do?" Well it happens to every Sierra eventually.
Here is the problem
There is a round bushing inside the transfer case called a "Shifter sheet or T/case bush."
Stock from the factory it is rubber. Over the years it gets worn and degrades from being in constant contact with gear oil. This is probably the most common problem with the Sierra. Don't worry. It is quite easy to fix!
For ease of understanding and a better view, I did this article with the t-case out of the vehicle. There is no need to pull the t-case out of the vehicle to do this.
Items needed
Hammer
long skinny flat tip screw driver
pliers (maybe)
rags
NEW bush
Let's start out sitting inside the vehicle.
1. Remove the transfer case shifter knob. (it just unscrews)
2. Remove the 4 bolts holding the rubber t-case shifter boot to the body.
3. Slide the rubber boot off of the shift lever and set it aside.
4. Now, Look down inside the hole, you will see another smaller rubber boot. You will need to remove this. It has a metal wire clamp holding it on but can be removed by hand or pliers. You may have to crawl under the vehicle to reach the ring but I never have needed to. See the pics below.
5. Once you remove the wire clip you can peel the rubber boot up and remove it from the shifter lever.
6. Now look at the silver ring around the bottom of the shift lever. It has a slot notched on each side.
7. You will need a long skinny flat tip screw driver and a hammer here. Place the screw driver half in and half on top of one of the slots. Push down. It should go inward just a little. You may need to push down on both sides of the silver ring
8. Tap the screw driver and turn the silver ring "COUNTER CLOCKWISE" just like a screw loosens. It will turn maybe 1/4 inch and pop upward.
9. Pull out the silver ring and the spring under it.
10. Pull out the shift lever and set it aside.
11. Clean out all the rubber and gunk inside the t-case shifter neck (sometimes there is nothing left at all!) There is usually a small flat rubber washer still in good condition that sits on the bottom of the hole. Remove this too.
12. Now get a flashlight and look down inside the t-case. There are two rods in the very bottom with a notch in each one. They are side by side running from front to rear. Most likely the notches are not lined up. Use that long screw driver and gently move them in line with each other. The notches should form a square open box when in line. If you find that you can't get the rods to budge, try having someone rock your vehicle fore and aft. Sometimes the drivetrain will be so bound up that it takes a while to get the rods into position. Just don't give up!
13. Insert your NEW Bush I chose to use a polyurethane one as they last forever!
14. Replace your shifter back into the t-case. It should fit right in.
15. replace the silver ring and spring and use the same method as taking it out to re-install it. Just make sure to turn the silver ring the other way!
16. Replace the rubber boot over the shifter lever.
17. Replace the metal wire clip
18. Replace shift boot and shift knob.
19. GO WHEELIN!!!
EASY AS PIE!! Takes about 20 minutes!
Post Posted: Fri Nov 19, 2010 8:41 am
:P Would of taken you longer to type it out!! :P
Post Posted: Fri Nov 19, 2010 8:43 am
Nar. I did that on another forum so I went back there and coppied it to post here LOL
Post Posted: Fri Nov 19, 2010 8:44 am
:roll: That's cheating...
:lol:
I have pictures if needed that I can post up.
Post Posted: Fri Nov 19, 2010 8:45 am
Never said I wrote it :-)
Post Posted: Fri Nov 19, 2010 9:00 am
:P You need a new sig... :P :roll:
Post Posted: Fri Nov 19, 2010 9:17 am
cheers guys. my new one seem to be bakerlite and there was no way it was going in, i just put two nothes either side so it could clear the pins or pin on the way down... im off to test her
Post Posted: Fri Nov 19, 2010 9:24 am
8O
Post Posted: Fri Nov 19, 2010 9:27 am
:shocked: x2
Post Posted: Fri Nov 19, 2010 10:09 am
i think if you add pics this should be moved to the good tech section.
in about to do this when my bushes get here :wink:
Think before you post to make AZ a better place :)
Post Posted: Fri Nov 19, 2010 10:29 am
Thought you may have got the bushes today :-(
Post Posted: Fri Nov 19, 2010 11:26 am
nah we are outside the next day area...even though the mail probably goes past my house to get to the sorting centre :roll:
Vehicle: Suzuki Sierra
Post Posted: Wed Jul 24, 2013 12:25 pm
Hey guys sorry I'm just doing this to my car after struggling for go knows how long I discovered someone has actually put a screw through the side of the transfer case and into the metal collar with the notches in it...any idea why? I also noticed 2 wires a red a yellow and what seems like a sensorthe wires have been cut?
Post Posted: Wed Jul 24, 2013 12:27 pm
as i said in your build thread its a 4x4 switch.
the screw is probably to stop the stick from falling out.
Users browsing this forum: No registered users and 359 guests
