It is currently Tue Nov 03, 2026 11:00 am
Post Posted: Fri Nov 19, 2010 11:39 pm
Hey folks, I have a 99 Jimny it sometimes has a grinding(?) noise coming from the front of the car. It seems to only happen after I start moving and it can be stopped by slowing the car to a stop where the noise slowly winds down and then thuds or by moving to transfer case gear stick towards 4h.
If has had this problem and fixed it or has any ideas it would be great to hear from you.
cheers
Post Posted: Fri Nov 19, 2010 11:52 pm
Start with checking the front brake pads and wheel bearings. Then work your way from there :wink:
Post Posted: Sat Nov 20, 2010 12:14 am
Front hub's are shitting...
Post Posted: Sat Nov 20, 2010 12:26 am
x2
one of the solenoids has a leak
Post Posted: Sat Nov 20, 2010 12:28 am
Need new ones? :lol:
i should have em somewhere.
Post Posted: Sat Nov 20, 2010 12:40 am
not 100% but just putting new hubs on might not fix it...
pretty sure people who have had this problem had to replace the solenoid.
if they get dirt in them they dont seal properly and allow the vac hubs to engage slowly.
manual hubs 100% fix it though
Post Posted: Sat Nov 20, 2010 3:20 am
ok thanks for the feedback. I'll look into the hubs
Post Posted: Sun Nov 21, 2010 12:39 am
ok I've had a look through the service manual and can't find any reference to the hub solenoid. Can you please give me a bit more info on this
cheers
Post Posted: Mon Jan 24, 2011 7:02 am
Just a quick update.. I think I found what was wrong with it. It looks like at sometime before I brought it someone has put the vacuum lines for the auto hubs around the wrong way. When it was in 2H the hubs were engaged and when I was putting it in 4H they were disengaging. Hence when it would grind and I put it to 4H the hubs would disengage and the noise would stop.
Post Posted: Mon Jan 24, 2011 7:05 am
So I was kinda on the money.. :lol:
Glad it's fixed mate...
Users browsing this forum: No registered users and 60 guests
