| Author |
Message |
bohuler
Joined: Wed Nov 10, 2010 9:18 am Posts: 1376 Location: Avonsleigh, Victoria
 Posted: Mon Nov 29, 2010 10:37 pm |
Smashed up my windscreen on the weekend drive with b4T, and this is how im fixing it.
The only bits im taking off it are the windscreen, carby and steering box. All will be swapped with bits from my lwb and put back on the car so it will run.
If no-one wants the whole car (minus the windscreen) i will part it out.
THE WIFE HAS STOPPED MY BEER SUPPLY UNTIL I SELL IT SO I NEEDS TO GO QUICK!
I will get more detailed pics when i collect it, this is just what i have atm.
The rear tail gate is bent, and a few minor bits here and there but absolute sweet f/all rust.
Ohh, the previous owner put a solid carbon fiber suzuki Z on the bonnet, im sure that adds atleast 50hp
There is no air box, just a pod filter on the carby intake hose, runs really well and has 211,000 ish on the clock.
More details to follow!
xedent
Joined: Mon Jun 15, 2009 11:30 pm Posts: 895 Location: Sunshine Coast, QLD
 Posted: Tue Nov 30, 2010 12:42 am |
Any chance the cluster has a tacko ?
_________________ My Maruti build, Click WWW
lockdup
Joined: Fri Feb 06, 2009 10:30 pm Posts: 490 Location: S.E melb
 Posted: Tue Nov 30, 2010 1:07 am |
Dibbs on transfer if you part it out
bohuler
 Posted: Tue Nov 30, 2010 3:32 am |
More pics. I think i will part it out already, unless someone comes along tonight and wants it whole. The motor is running really well, no knock or noise. The gear box is making a bit of noise and the rear diff had a couple of meters of barbed wire wrapped around it and has buggered the pinion seal (and caused spray of oil under body as i drove home.
I think i will take the doors as well and the jack shaft.
The tires are 4 almost spanky new a/t. 215/75/15 on steel rims. The spare has a good bit of tread on it too.
bohuler
 Posted: Tue Nov 30, 2010 3:37 am |
What sort of price are the clusters going for? I think i got ripped off when i bought my car and needed one and paid $150 2 years ago.
Transfer case, i was thinking $150? Am i ripping myself off or giving you a bargain?
_________________ Life's short, fiddle with your willy while you can
xedent
 Posted: Tue Nov 30, 2010 7:46 am |
I'll take the cluster, think you got ripped off, want33s sold them for around $25 if I remember, I'll give you $50 ?
bohuler
 Posted: Tue Nov 30, 2010 7:58 am |
sold for $50  unless someone comes along tonight and takes the whole car. finlay113 is looking at taking the body, chasy, door, and bonnet so i will start stripping tomorrow.
If someone wants the motor, let me know asap as it would be better to see it running then just letting me tell you about it
xedent
 Posted: Tue Nov 30, 2010 8:01 am |
No worries, just send me a pm with your bank details, when you want cash
lockdup
 Posted: Tue Nov 30, 2010 10:10 am |
bohuler
 Posted: Tue Nov 30, 2010 6:06 pm |
Could you try again lockdup, i just checked now and royce musta eatten the pm in his sleep
bohuler
 Posted: Wed Dec 01, 2010 6:39 am |
I'm parting it out now
The body, chassy, doors, front clips, transfer case and dash cluster are gone.
Whats left is the complete motor with starter, alternator and carby-(off my lwb) $350 *sold* or $400 with the 5 speed gearbox
$100 for the 5 speed gearbox, it seemed to make noise when i drove it home, but changed gears quite smoothly.
Front diff complete hub to hub with diff centers, rotors and calipers $120
Rear diff hub to hub with drums and diff centers. Unfortunately the guy i bought it off ran over a fence and wrapped barbed wire around the uni joint and forced wire into the pinion seal so its leaking and needs to be pulled apart and panel beated a bit. $90
Fuel tank, small crease and leak near the drivers leaf, i fixed with liquid metal and no more leak now. Apart from that its straight no dings $30
Front standard metal bar with lights $30
Rear standard bar with lights $30
Spare wheel carrier $20
I think thats about it, i will get pics tomorrow before i start pulling stuff off and once its all off!
5 tires and rims 15x5 1/2 JJ DOT 5 58 (pic above) Roadstone A/T 215 75 15. 4 tires are pretty much brand new as shown in the pic above and the spare has more then enough tread to be roadworthy
If there is anything else that i've not listed and is on the zook and you want it, let me know!
phantomzook
Joined: Thu Dec 02, 2010 7:57 am Posts: 3 Location: NE Melbourne
 Posted: Thu Dec 02, 2010 8:01 am |
bohuler
 Posted: Thu Dec 02, 2010 8:10 am |
i found out today that one of the good tires if rooted, looks like the sideway has been staked with a tree. So its 3 really good tires and 1 average one, and a rim. $150 for the lot?
bohuler
 Posted: Sat Dec 04, 2010 9:10 pm |
A few more pics and a bump!
Front bar standard bar in good nick, $30
Rear standard bar in alright nick, a bit of a bend, fixable $20
Both come with the lights. I will check and post up later if they are cracked. I think the front ones are fine, but the rear drivers reverse one has a crack, but will check.
Still have the front and rear diffs, complete hub to hub with diff centers.
3 great tires with heaps of tread, a spare and a rim (i will get rid of the stuffed tire) $150
