It is currently Fri Jul 31, 2026 6:12 am
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2  Next
Post Posted: Fri Dec 10, 2010 12:09 pm
Does a wheel... (rim, tyre and tube) At say 60psi pressure have better boyance than the same at say 10 psi.
Boyancy being flotation in water..
Regards Bill
Post Posted: Fri Dec 10, 2010 12:11 pm
i know nothing about Physics/Engineering, but i'd say no as it's still dispersing the same volume of water no mater what psi.
Post Posted: Fri Dec 10, 2010 12:17 pm
would'nt it be heavier as (no matter how little) more air compressed into a small area making it denser?
maybe lol
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Dec 10, 2010 12:18 pm
A higher psi stretches the tyre for more volume (thus displacement) so would probably aid boyancy, compared to a lower psi. Change in density would be negligible (compressed air is still a hellova lot lighter than, say, metal)
Post Posted: Fri Dec 10, 2010 12:31 pm
The change in size (i.e. displacement) of a tyre would be pretty small.
That said, the change in weight wouldn't be much either. It probably wouldn't make a whole lot of difference.
My scuba tank weighs around 2kg more full than empty. But thats nearly 4000psi, so 60 wouldn't make a lot of difference.
I want my old sig back :(
Vehicle: Jeep
Post Posted: Fri Dec 10, 2010 1:40 pm
Regards Bill
GregDixon actually discussed this pressure difference in another thread, about tyres on road and sand... cant find it at the moment... but if i remember what he said, no it would not make it more buoyant, as the tyre will only inflate to a certain size... the more surface area you have, ( displacement of water ), will give the surface tension of the water, more area to push back on, and the more buoyancy it will have... but if you had really big tyres, like 35's or bigger, on a sierra, then it may have a good chance at being fairly buoyant :roll:
A bit of useless info... if you and your zook are ever caught underwater, you can breath from the air in the tyre, it will be stale, but it will keep you alive... for a while... :lol:
Post Posted: Fri Dec 10, 2010 1:56 pm
^^^ watch 007 much :wink:
i think this was the thread with the tech from greg?
http://auszookers.com/index.php?name=Fo ... hlight=psi
Post Posted: Fri Dec 10, 2010 2:04 pm
why does a 5c coin sink - but a 500 ton ship float....
what macbear said - displacement. The amount of water an object 'displaces', must be heavier than the object, for it to float.
so a tyre with more air (higher psi) in it will make it heavier, ever so slightly - assuming the tyre size stays the same, the amount of 'displaced' water is the same - hence more air in the tyres will make it LESS boyant....but maybe not enough to sink it
My Grand Vitara
Post Posted: Fri Dec 10, 2010 2:06 pm
I think it was from one of the Transporter movies......and i think mythbusters tried something similar
My Grand Vitara
Vehicle: Jeep
Post Posted: Fri Dec 10, 2010 5:18 pm
Bingo ! Yep i saw it on Mythbusters... it is difficult, but is doable... i have valve tools on all my valve caps, so if you just undo the valve a bit, and stick your mouth over the valve, its easy, but if you have to push the valve in by hand, it is much more difficult... :roll:
Post Posted: Fri Dec 10, 2010 8:19 pm
no the pressure will make no difference to the boyancy.
Post Posted: Sat Dec 11, 2010 2:40 am
Air can hold 1kg in water, that is, pure fresh water, nothing but H20, 1kg, in marine or salt water, it can hold, (average, the marine environment changes dramatically with location, summer, winter etc) 1.027kg
If you have a air container that is ay, 1 litre, then it will hold up, 1kg, if you add twice that volume of air, pressurize the container, it will hold an infinitesimally smaller weight. I can do the calcs, but my papers are home.
Displacement is the key here.
Concrete weights around sg2, so for the sake of the argument, it does, exactly.
So a cubic meter of concrete will weight, 2,000kg, it is a perfect cubic meter, so in water it displaces 1 cubic meter, so it weighs, 1,000kg.
Water is heavier than us, this is why we float, we displace more water than we weigh.
A drum displaces 250kg, it is exactly 1 cubic meter, it will float at 1/4 its volume, and support 750kg.
Hope that is understandable, im not a lecturer, but as a skipper, we do stability calculations a lot, we have to make sure we can float, not turn over and sink.
Post Posted: Sat Dec 11, 2010 8:13 pm
Its this
vs this
maybe lol
A physicist would do a lot of calculations and tell you which one of these negligible changes is greater, an engineer will tell you that they're both negligible ;)
Post Posted: Sat Dec 11, 2010 9:14 pm
I'm an engineer. They're noth negligible. :P
Post Posted: Sun Dec 12, 2010 9:37 am
I'm a mathematician. And I would trust the engineer in these matters. :P
It is negligible for normal pressures. If you go up to a couple of thousand PSI the air would be liquid and have a similar density to water!
Post Posted: Sun Dec 12, 2010 9:43 am
no idea what you lot are talking about but i still want to contribute to the thread so here is a photo of a hole my dog made.
Post Posted: Sun Dec 12, 2010 9:46 am
Ducks also float in water So, logically... If...it...weighs the same as a duck......its made of wood. and therefore a witch!
If you a confusing witches with tyres, I recommend you seek help!
Clearance Hole Technology :P
:D :D :D good dog :lol: :lol:
Post Posted: Sun Dec 12, 2010 9:53 am
lol shep...
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Vehicle: SV420 SE416SWB SE416LWB SIERRA
Post Posted: Sun Dec 12, 2010 10:25 am
simple answer take 2 wheel to your local pool one with 10psi one with as much as your game to put in it, chuck them both in and give $5 to some kid whos willing to drag them out if they sink.
Vehicle: 2004 SQ625 GV
Post Posted: Sun Dec 12, 2010 10:43 am
A radial tyre at different pressure will float the same especially a 4x4 tyre, overall casing growth and added weight from the air is very insignificant.a bias tyre carcass will grow more but in smaller sizes I feel it would still not make a difference to boyancy. As everyone is saying it is more about displacement and weight if you want things to float.
We have however worked out some rough figures regarding 40.00R57 earthmover tyres. At 110 psi around 40kg of weight is added to the tyre from 0 psi. This tyre weighs around 3.5 tonne and 5 tonne with rim so 40kg is nothing.
Post Posted: Sun Dec 12, 2010 10:46 am
Surely that would float :lol:
Post Posted: Sun Dec 12, 2010 10:53 am
I haven't seen it personaly but I believe it will.
Post Posted: Sun Dec 12, 2010 10:55 am
so i was right in a vague sort of way? :wink:
Post Posted: Sun Dec 12, 2010 12:10 pm
More or less.... The displacement and weight changes will be so small in a tyre that it really won't make any difference...
Post Posted: Sun Dec 12, 2010 8:07 pm
Shep,
If the hole fills with water, will you dog float?
Robert
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sun Dec 12, 2010 10:50 pm
Post Posted: Sun Dec 12, 2010 11:40 pm
Post Posted: Sun Dec 12, 2010 11:44 pm
ajsr wrote:
wht then do dead bodies float??
not three days after death but straight away???
Only the fat ones :wink:
Post Posted: Mon Dec 13, 2010 5:36 am
if they die before they go in the water they still contain air, but if you drown them they will have lungs filled with water therefore sink.
it took me a few trys to get this one right.
Users browsing this forum: No registered users and 539 guests
