It is currently Mon Oct 19, 2026 5:06 am
Post Posted: Mon May 12, 2008 12:07 pm
I've got some engine work happening at the moment and have been thinking that further down the track i'll be needing an upgrade in the clutch department. Currently I have a stock Sierra 5 speed with (I think) a Sierra flywheel and Centreforce clutch.
I was thinking my options are a custom clutch but this still leaves the stock transmission that might not fare so well with the extra horses. So perhaps a Vitara 5 speed, converted to remove the transfer case?
Vehicle: WR250F/Jeep XJ
Post Posted: Mon May 12, 2008 6:58 pm
what sort of power are you going to be pulling?
If you are geared remember that the force at the clutch/engine interface will possibly be less than stock. When I built my zook, mid range cam, bigger carby, modded intake, extractors with 34" swampers, 4.57 diff gears and 4.9 TT tranny i just dropped a standard clutch in. It never had an issue at all. All the stress will be further down the driveline --> driveshafts, R&P, axles, cvs etc.
Although if you are producing some serious power then you might want to upgrade :wink:
Post Posted: Mon May 12, 2008 9:15 pm
Around 150HP i'm guessing. G16 16 valve with an Eaton M45 supercharger.
Users browsing this forum: No registered users and 242 guests
