It is currently Mon Nov 02, 2026 11:01 pm
Post Posted: Tue Dec 14, 2010 6:49 am
So last night I tried to turn on the heater for the first time in ages, and it didn't work!
Today I checked the heater fuse, it's fine. It's only the fan that's not working. Not on any setting.
Any suggestions? All my searches returned the opposite faults, fan working but not heating.
Heater is aimed at feet/demist.
Cheers!
Post Posted: Tue Dec 14, 2010 6:53 am
its summer wind your window down :lol:
Post Posted: Tue Dec 14, 2010 6:55 am
switch or fan speed resistor
Post Posted: Tue Dec 14, 2010 6:57 am
I had my window down...It was fucking cold out lol and i was in a T and boardies lol.
Sigh, I hate electrical crap. Where abouts are the fan speed resistors/switch?
Post Posted: Tue Dec 14, 2010 6:59 am
Or the fan motor..
Post Posted: Tue Dec 14, 2010 7:36 am
steak_knife wrote:
Or the fan motor..
ohhhh .......... good one ....... that would cause a problem to.
Post Posted: Tue Dec 14, 2010 11:43 am
heater control cable to the tap in the engine bay ?
Vehicle: LPG 1.6 Sierra
Post Posted: Tue Dec 14, 2010 12:05 pm
Edit poopy - I need to read the whole post before I offer advice
Post Posted: Tue Dec 14, 2010 12:07 pm
i've had 2 issues with mine:
1- cable came off at the engine side of the firewall stopping it putting the coolant through... put it back on and worked great.
2- loose wire to back of heater unit stopping fan working - tighten screw = working great.
Post Posted: Tue Dec 14, 2010 12:14 pm
My fan stopped working, and all the fuses were good, so I took apart the switch and cleaned it, that fixed it.
I just cleaned the copper contacts with an eraser, got them all nice and shiny, then put it back together. The switch is a pretty common fault, especially if you do not use the heater often, and you have a lot of moisture/dust.
The switch is behind the panel with fan speed settings, you can take it apart with three Phillips screws. Just be careful not to loose the spring and ball bearing that are inside the switch.
You can test the motor and wiring by jumping the switch the wires over at the connector on the back of the switch. If you can get it to run by jumping the wires, then you know the switch is dirty/broken.
Users browsing this forum: Google [Bot] and 313 guests
