It is currently Tue Nov 03, 2026 4:34 pm
Post Posted: Thu Dec 16, 2010 7:24 am
I got a 1.6 tbi swift engine in my shed trying to put in my zook wondering what people have done about the distributor cause i have the 90 degree angle drive but it's not going to work as the 1.6 dizzy is to sort. i am kinda stuck of what to do, should i be thinking about cutting onto the fire wall (kinda don't wont to) or is there another option or should i just cut the whole idea of doing this conversion?
Post Posted: Thu Dec 16, 2010 7:34 am
Not a switft one. I got mine from a jap import vitara.
Cracking motor!!!
Post Posted: Thu Dec 16, 2010 7:37 am
are they the same setup?
Post Posted: Thu Dec 16, 2010 7:42 am
AFAIK they are. Just the distributor arrangement would be different. Pretty easy to wire up aswell.
Post Posted: Thu Dec 16, 2010 7:47 am
haha that's where i'm having my problem.
Post Posted: Thu Dec 16, 2010 7:48 am
Can the gut's out of the dizzy's be swapped to a vit one??
Post Posted: Thu Dec 16, 2010 8:11 am
dont let it beat ya bails,sorry i missed your call man ill give ya a buzz in 5.
if it was all gonna be too hard surelyyou can box a bit out of your firewall.far from perfect i know but still.
Post Posted: Thu Dec 16, 2010 8:17 am
this is the 1.6 dizzy which as you can see the shaft is too sort and different.
and this is the 1.3 dizzy. this is the length the dirve needs to be if i want to run the angle drive
Post Posted: Thu Dec 16, 2010 8:19 am
is it a 8v or 16v i can help ya with a 16v vitara head. it might be cracked but
will have what ya need for the swift head.
i am in town next week and can find out if it is still available then.
Post Posted: Thu Dec 16, 2010 8:21 am
yer kinda didn't want to cut into the fire wall but if that is going to be the only way well i better get out the grinder. the coolant lines are allso in the way but that is easy causr i can fab up a 90 degree flange for it at work.
Post Posted: Thu Dec 16, 2010 8:22 am
yer it is a 16v. that would be sweet if you have anything that will help.
Post Posted: Thu Dec 16, 2010 8:25 am
the fella that does my roadworthy's offered me a blown up vit motor, hopefully he still has it. i will find out next week for ya.
Post Posted: Thu Dec 16, 2010 8:30 am
yer that will be great. thanks for that shep
Post Posted: Thu Dec 16, 2010 8:31 am
All that 1.6 has is a reluctor for the ECU pickup. It looks exactly the same as whats in a stock 1.3 dizzy.
Lil Foot!
Post Posted: Thu Dec 16, 2010 8:34 am
:D
Post Posted: Thu Dec 16, 2010 8:35 am
JrZook wrote:
reluctor
WTF?
Post Posted: Thu Dec 16, 2010 8:37 am
joeblow wrote:
:D
So he just need's a yellow rocker cover?? :?
Post Posted: Thu Dec 16, 2010 9:07 am
joeblow wrote:
JrZook wrote:
reluctor
WTF?
Never heard of a magnetic reluctor pickup? Its an inductive sensor.
Lil Foot!
Post Posted: Thu Dec 16, 2010 9:39 am
joeblow wrote:
:D
so you are just running a 1.3 dizzy here yer? dosen't affect it in any way?
and how have you got the coolant setup running? can't quiet figure it out.
Post Posted: Fri Dec 17, 2010 1:20 am
JrZook wrote:
joeblow wrote:
JrZook wrote:
reluctor
WTF?
are you talking about a hall effect sensor?
Post Posted: Fri Dec 17, 2010 1:25 am
crewsy wrote:
JrZook wrote:
joeblow wrote:
JrZook wrote:
reluctor
WTF?
Different things that do a similar job. The reluctor is also known as a VR sensor, VR meaning variable reluctance.
Post Posted: Sat Dec 18, 2010 2:11 am
bails wrote:
joeblow wrote:
:D
hey bails. as joe seems to have a good supply of alloy and the tools to machine it, he fabbed up a housing that bolts to the rear of the head and accepts the thermostat housing and temp sender
Post Posted: Sat Dec 18, 2010 7:15 am
mr.green wrote:
bails wrote:
joeblow wrote:
what he said.....and top pick shows angle drive in the vehicle. 1.6 tbi uses same internals as the 1.3 dizzy.
:D
Post Posted: Sat Dec 18, 2010 9:16 am
mr.green wrote:
bails wrote:
joeblow wrote:
:D
yer been looking at that kinda figured that's what's been done. still not sure how the dizzy is working.
Post Posted: Sun Dec 19, 2010 8:58 am
well unless joe wants to chime in and shed some light i would say screw the 1.3 dizzy in with the vit cam and angle drive you have and see if it runs.
Post Posted: Sun Dec 19, 2010 9:42 am
yer tried that, the 1.3 is too long, but could be cut down i guess.
Users browsing this forum: Google [Bot], Google Adsense [Bot], phlix and 367 guests
