It is currently Thu Jul 30, 2026 8:10 pm
Post Posted: Fri Dec 17, 2010 2:54 pm
need some help or info on methods of lifting my vit
ironman kit?
king springs (or similar), commo shocks?
calmini is probably a little out of reach lol
tacky looking ebay kit.. robust or something?
Vehicle: Jeep
Post Posted: Fri Dec 17, 2010 7:05 pm
ironman kit?
From what i have heard and seen, King Springs are good, and the commo shocks allow good axle travel/articulation, this combo is good if you dont want to spend to much...
Another option not mentioned, may be a Dobinson 40mm Kit, still fairly cheap...
I have the Performance Rated ( +50kg ) 35mm Ironman Kit on my GV, and i am very happy with it, got more than 35mm lift in the rear, 55mm empty, its perfect for what i wanted and needed, its the same one on ebay, and they arnt too expensive if funds are low... i use my GV 90% road, and 10% Offroad, and handling both off and on road, has improved alot, havnt had any under body bangs or scrapes offroad since fitted... :D
It really depends on what you expect of your Vit, and if will be mostly road, with the weekend offroad, or doing alot offroad, and how much of a load will be in your Vit, like a load of camping gear, or 4 or 5 people... as to what make and option you choose, as the springs will have different load/firmness/handling settings.. complete suspensio kits usually come as a midrange option... so these are all things to consider... hope this helps... :wink:
Vehicle: SJ51T
Post Posted: Sat Dec 18, 2010 3:24 am
If your not going any bigger then 30 inch tyres go lifted kings, strut mount flip on the front and commo shocks in the rear.
Also if you need spacers to level it out letme know. I have a set lying around.
Post Posted: Sat Dec 18, 2010 11:05 am
so where can i get king springs from?
and how do i know which ones to get? prices?
how much is a dobinsons kit, and more importantly is it any good?
thanks for your help so far
Post Posted: Sat Dec 18, 2010 2:21 pm
anyone else got any info/advice?
i might just buy my zook a nice christmas prezzie if i can work out what i wanna do..
Vehicle: SJ51T
Post Posted: Sat Dec 18, 2010 6:41 pm
you have a PM.
Post Posted: Sat Dec 18, 2010 8:55 pm
http://auszookers.com/index.php?name=Fo ... ic&t=17472
:roll:
Users browsing this forum: No registered users and 307 guests
