It is currently Thu Jul 30, 2026 7:24 pm
Post Posted: Thu Dec 23, 2010 9:15 am
does any one here run after market gauges that dont fog up or is this to much rice for a zook :D
I run speco gauges and mine are always fogged up, this is in a soft top zook
I've had vdo but there a no go, so im guessing oil filled would be the way to go
josh AKA Bazook
Vehicle: 4wd
Post Posted: Thu Dec 23, 2010 9:16 am
What about some never fog glass?
Watch out or you'll get sued.
Post Posted: Thu Dec 23, 2010 9:20 am
yeah liquid filled, thats what its for
Post Posted: Thu Dec 23, 2010 9:37 am
I Run VDO Oil Pressure & VDO Voltmeter, they work fine, and don't fog up...
the liquid filled ones are to stop the needle fluctuating rapidly making them easier to read and giving you a more accurate reading.
Stocker
Vehicle: LWB Sierra & XL7
Post Posted: Thu Dec 23, 2010 10:35 am
I've never had or seen Autometer guages fog up, I have had one of their liquid filled guages that the liquid leaked out of it though ;)
'92 Vitara & Camper trailer
Post Posted: Thu Dec 23, 2010 10:49 am
I've got Equus oil pressure & voltmeter, mounted side by side in the bottom DIN slot - one fogs, the other doesn't, and for the life of me I can't figure out why - they're both exposed to the same temperature/humidity changes etcetera.
Post Posted: Thu Dec 23, 2010 2:46 pm
On a side note: usually, fogging in a closed space (be it a head lamp, a tail light or some other enclosure) means there's humidity trapped inside. On head lamps for example, you have a little rubber tube which allows humidity to escape and the inside gets dry. Maybe it's worth checking if you have the same for the indicators, and one of them has the air vent obstructed.
Suzuki JB43 2007
Post Posted: Thu Dec 23, 2010 7:21 pm
I used to think so myself - but - both gauges are open to the atmosphere on the back - there's no seal or anything - the lamp is in a plastic holder that snaps into a hole, and I would have thought that the warmth from the lamp would bake that moisture out.
Post Posted: Thu Dec 23, 2010 7:25 pm
my specos fog up 2, but only 2 of them, i thought it must have been from me hoseing them!
Post Posted: Thu Dec 23, 2010 7:54 pm
i wonder if marine ones are the go
josh AKA Bazook
Post Posted: Thu Dec 23, 2010 8:45 pm
Autometer liquid filled gauges are crap... The numbers all fall off the face.
If you want GOOD quality gauges buy PRICOL in plain or liquid filled.
Users browsing this forum: Google [Bot] and 321 guests
