| Author |
Message |
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Fri Dec 24, 2010 8:46 am |
motor has had a full rebuild, slapped it into the car today.
hooked every thing up. then had problems with the dizzy, had no spark.
so i fiddled around with it and has got spark now.
but now it wont start  .
theres spark and theres fuel, and the timming is wright.
any body know whats happen. it has lost me
alex
Joined: Sat Aug 16, 2008 11:30 pm Posts: 2151 Location: Brissy
Vehicle: Nissan
 Posted: Fri Dec 24, 2010 8:49 am |
are you sure that your timing is on number 1 and not 4
_________________ Pearce-toff Racing
zooky08
 Posted: Fri Dec 24, 2010 8:52 am |
yep timming is spot on
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
alex
Vehicle: Nissan
 Posted: Fri Dec 24, 2010 8:58 am |
what did you do in teh rebuild? is it a standard engine???
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
will it fire with a little fuel down the carb??
if not your spark is wrong
zooky08
 Posted: Fri Dec 24, 2010 9:04 am |
the head got recon(valves, stem seals, guids sleves,shaved)
block got bored to 40 thou with matching piston and ring, also shaved.
motor is a g16a with g13ba head
put fuel down the carb doesnt really do ny thing, after a few cranks it back fires out of the carb
royce
 Posted: Fri Dec 24, 2010 9:09 am |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Fri Dec 24, 2010 9:13 am |
Timing (either cam or diszzy) is DEFINATELY out of wack.
Check both again.
zooky08
 Posted: Fri Dec 24, 2010 9:50 am |
royce is right, turn dizzy 180, and its started.
a lil bit rough, im guessing im one tooth out on the dizzy
alex
Vehicle: Nissan
 Posted: Fri Dec 24, 2010 10:33 am |
zooky08 wrote: royce is right, turn dizzy 180, and its started. a lil bit rough, im guessing im one tooth out on the dizzy
