It is currently Thu Jul 30, 2026 7:58 pm
Post Posted: Sun Dec 26, 2010 4:15 pm
Hi
I have sj80 1996 model and i would like to know which lift kit shall i use to be able to fit 33" tires
Thanks
Vehicle: jimny
Post Posted: Sun Dec 26, 2010 7:24 pm
Hey I don't think you will fit them easily, big suspension lifts don't work In sj80 suzukis. I'm sure one of the coily owners will chime in with some information. Welcome to auszookers
Post Posted: Sun Dec 26, 2010 7:50 pm
guard chop and 2 in body will fit 33
i had guard chop and 31 with only 1 in lift
u will need to so joe blow and get some cromo cv though
and put in a sierra tc with some 6.5
y do u want 33
i had 4.1 with 31 and i out drove most cars because is was so stable
it was the best car to drive it was so much fun
Vehicle: MY2019 Jimny
Post Posted: Sun Dec 26, 2010 8:58 pm
What motor are you running mate?
Your stock motor won't be able to turn those big tyres up the sand dunes...
Post Posted: Sun Dec 26, 2010 9:01 pm
2" spring lift and 2" body lift should do the trick with some minor chopping on the front bumper mounts, as g_b_w says you definately wanna change your transfer and get some lower gears, i went 30's on my Coily and even they made a big change to my ratio's so 33's would be massive probably to big for a stock g13b imo.
Richo
97 Coily 2" susp lift 2" body lift + more
Post Posted: Sun Dec 26, 2010 9:30 pm
Find yourself some jimny front shock mounts, eliminates the shitty strut set up in a coily. Then you will have shock/spring set up in all
4 corners. It could be harder for you due to location, but try also a front diff conversion from a late model leafy sprung Sierra. You can easily buy parts then, axels, cv's lockers etc. And you will most defianately need the transfer from a leafy Sierra also.
Post Posted: Mon Dec 27, 2010 1:49 am
I have 1.6 engine in my sj
Post Posted: Mon Dec 27, 2010 1:52 am
Thanks all for the information
Is there any online shop sell the 2" lift kit and the body lift kit
Post Posted: Mon Dec 27, 2010 1:55 am
body lifts from here... http://auszookers.com/index.php?name=Fo ... ic&t=15518
not sure about the spring lifts, i think alot of people are running the ebay kit??
Vehicle: 4wd
Post Posted: Mon Dec 27, 2010 1:57 am
Rancho do a 2" kit for the coily. I had one in my coily years ago.
Watch out or you'll get sued.
Post Posted: Mon Dec 27, 2010 4:59 am
What sort of terrain are we talking? I assumed sand too, but you never know.
I think even a 1.6 would struggle a bit in sand, especially with wide 33s.
Users browsing this forum: Google [Bot] and 278 guests
