It is currently Sun Oct 18, 2026 11:55 pm
Post Posted: Sun May 25, 2008 4:25 pm
Um i blew my head gasket a few weeks ago and i wanna get it goin for queens birthday weekend!
I have a mechanic over the road who said he will check it out one night during the week but i have tomorow off work so might takel it my self?
Would just be rippin the head off so he can tell if it's all good.......
Whats involved i remeber last time he had it off in about 20 minutes but what do i have to do to get it off?
CHEERS GUYS!
back in a built sierra!
Vehicle: Clown Car..
Post Posted: Sun May 25, 2008 5:14 pm
mark all req. vacume lines, remover exh. manifold, remove intake man.dump water/coolant from entire engine, might have to remove radiator to get to screws on timing cover, remove them, take off rocker cover, mark pullys/belt/crank/cam location(or zip tie everything in place) remove headbolts, head MAY require a love tap to 'break the seal' and SHOULD come off relatively easy.. pretty much it.. someone will chip in if i forgot anything im sure...
suggestion: Get a cardboard box and mark one end as FRONT, when removing bolts from head etc puncture cardboard with a screwdirver and insert bolts into cardboard as they are removed. . front left, rear right yada yada yada.
just hope THIS doesnt happen...
Post Posted: Sun May 25, 2008 6:26 pm
Thanks heaps man!
Hopefully the block is all good and i'm sweet to wheel queens birthday away....... :twisted:
Post Posted: Sun May 25, 2008 8:33 pm
JUST RIP THE HEAD OFF. GET IT CRACK TESTED. THEY BLOCK ALL THE HOLES AND PUMP WARM OIL IN. IT SEEPS THRU CRACKS. GIVE IT A HAIRCUT AND BACK IN. DON'T LET EM TRY TO SELL YOU NEW VALVE GUIDES. 500 BUCKS LATER.
Post Posted: Mon May 26, 2008 11:23 pm
If the motor needs rings and every thing i'm just buy one off a bloke i know and wack a whole new motor in.....
Didn't work on it today cause i had a huge sesion on the piss last night so slept half the day then spent the rest with the missus to make up for a sloppy night last night! :wink: Was worth it but.....
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 442 guests
