It is currently Fri Jul 31, 2026 1:25 am
Post Posted: Tue Dec 28, 2010 3:05 am
Since i put my steering damper on my jimny, i now get a wobble at the steering wheel between the speed of 60 to kph after 70 it's fine.
Anyone know what it could be?
Vehicle: I drive your mum
Post Posted: Tue Dec 28, 2010 3:14 am
Steering dampeners dont fix wobble, they just mask it. Take it off and see if its still there. If it is check your wheel bearings, king pin bearings, steering linkages and radius arm bushs.
Layto....
Post Posted: Tue Dec 28, 2010 3:30 am
It only started when i put the Return To Center Damper on?
Post Posted: Tue Dec 28, 2010 3:31 am
http://auszookers.com/index.php?name=Fo ... ic&t=15499
Post Posted: Tue Dec 28, 2010 3:38 am
i dont think it's the same problem because it's not a constant wobble
Post Posted: Tue Dec 28, 2010 3:52 am
I think most of thier wobbles are only there from 60 to 70 or 70 to 80 km's
Post Posted: Tue Dec 28, 2010 3:54 am
did you center it properly?
Post Posted: Tue Dec 28, 2010 4:05 am
Yep it's spot on i think. if i let go of the wheel it goes dead straight.
Post Posted: Tue Dec 28, 2010 5:55 am
Isn't still under wty??
Take it to a Suzuki dealer, it's a known problem & can be fixed with king pin shim's. ( fixed for a time)
Post Posted: Tue Dec 28, 2010 6:41 am
Will they fix it because of all the mods?
Post Posted: Tue Dec 28, 2010 6:45 am
Still have the std stuff??
What have you done?? Lift & tyre's??
As said, it is a known problem, if one dealer won't do it, go to another, if they won't, jump on Suzuki Aus..
I used to overlook some mod's, others may do the same..
Post Posted: Tue Dec 28, 2010 9:08 am
I dont have the std wheels.
I have 80mm lift and 30" muddies. But there is one Suzuki dealer near me and the others a over a 1hour away.
Users browsing this forum: Google [Bot] and 326 guests
