It is currently Fri Jul 31, 2026 1:16 am
Vehicle: 1986 Sierra SJ50
Post Posted: Mon Nov 08, 2010 12:28 am
Does anyone know the official description for the 4 x nuts which hold the rear brake drum on... they look like m12 but cant tell what the thread is. Car is SJ50 N/T 1986.
I've got 2 x stripped nuts and so need to order some more over the phone and get them delivered as cant go get them! :(
No local wreckers have any SJ50's to scavenge off.
Need nuts ASAP as car out of action until the wheel can be stuck on properly.
Post Posted: Mon Nov 08, 2010 12:31 am
same as wheel nuts,U bolts etc. M12x1.25
Post Posted: Mon Nov 08, 2010 12:44 am
Your right... the nuts just thinner so has smaller OD...
CHeers
Post Posted: Mon Nov 08, 2010 12:48 am
dont worry about the smaller OD that is a jap size and is hard to find in Aussie.
the standard nut will fit, grab a handful for ya spares kit.
Post Posted: Mon Nov 08, 2010 12:54 am
yep, get 10 Nylocs and 10 Flat washers and your set for another 10 years
Post Posted: Mon Nov 08, 2010 1:09 am
thats the 10/10/10 rule
Post Posted: Mon Nov 08, 2010 1:14 am
Hopefully Porters has a nut for the job.
Thanks guys.
Post Posted: Mon Nov 08, 2010 1:18 am
If porters can't help try Blackwoods on Mary St.
Vehicle: 91 Sierra
Post Posted: Sat Jan 08, 2011 3:35 am
Casually bringing a 88 sierra tintop back to rwc, while replacing pads and cylinders i stripped a nut for the brake drum while putting it all back together. Found this thread :lol: , could not find M12x1.25 nylock's and ended up with high tensile M12x1.25 instead.
Using new nuts;
5 out of 8 go on no problem.
1 won't tighten, it sounds like it's jumping over the bolt thread ?
2 do up but have play ? ie. when completely on the bolt but not tight it wiggles 8O only slightly but it does.
Question time - can i replace the bolt bits ? if so how ? can i do it ' shep tech ' style with a BFH ?
ta
Post Posted: Sat Jan 08, 2011 5:21 am
4wd reckers in gympie has a yellow narrow. Got the windscreen off it. Not sure if it has diffs, cant remember
Vehicle: 2018 DMAX
Post Posted: Sat Jan 08, 2011 6:42 am
Glad this thread just turned up, ive spent the afternoon trying to find a nut for the drum... old wheelnut worked sweet
Users browsing this forum: Google [Bot] and 332 guests
