| Author |
Message |
sickzuk1
Joined: Mon Jul 12, 2010 8:04 am Posts: 289 Location: Cairns, Queensland
 Posted: Sat Jan 08, 2011 2:15 pm |
Ok. Well I am absolutely sick to death of trying to find a little stick to let down my Tyre's every time I get bogged. SO. does anybody have a tyre deflator/set that they would like to part with for cheap?
_________________ My build: Click WWW
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Sat Jan 08, 2011 5:49 pm |
What about ya ignition key.
You generally have this when ya go wheelin.
_________________ Bad decisions make good stories.
PJ.zook
Joined: Sat Oct 24, 2009 10:30 pm Posts: 845 Location: Melbourne
 Posted: Sat Jan 08, 2011 8:33 pm |
I know they arent cheap, but ARB's version of the EZ-deflator are brilliant. If thats too expensive, you could just buy a valve core removal tool (maybe $5) and just remove the valve whenever you want to deflate. Practice first on a spare tyre though to get the feel of what is happening. You want to unscrew the valve core all the way out and have it sit there on the end of the tool still inside the valve body as the air is rushing out, you dont want it flying off in any direction. Its rough and very difficult to get pressures right, but if you want cheap...
Choppy
Joined: Fri Nov 06, 2009 10:30 pm Posts: 1074 Location: sunshinecoast
 Posted: Sat Jan 08, 2011 8:57 pm |
You can buy the end fittings which are on your general servo air pumps/ air compressors and the like. The clips which lock down and remove the valve as shown in the pic, releases air alot quicker
steak_knife
 Posted: Sat Jan 08, 2011 9:03 pm |
Choppy wrote: You can buy the end fittings which are on your general servo air pumps/ air compressors and the like. The clips which lock down and remove the valve as shown in the pic, releases air alot quicker
They open the valve, not remove..
Good thinking...
Westie
Joined: Tue Jul 04, 2006 11:30 pm Posts: 1417 Location: Caloundra Sunshine
 Posted: Sat Jan 08, 2011 9:52 pm |
sickzuk1 wrote: Ok. Well I am absolutely sick to death of trying to find a little stick to let down my Tyre's every time I get bogged. SO. does anybody have a tyre deflator/set that they would like to part with for cheap?
1) let tyres down before entering bog.
2) CHEAP is finding a stick.
3) Using a deflator in the mud will render it useless in a short time.
4) Refer to 1&2.
5) KEEP OUT OF MUD and you won't get bogged.
Hope this helps No 5 works the best I have found.
_________________ Steve W
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Jan 08, 2011 9:56 pm |
just don't get bogged
i would suddest that nothing quality is cheap, so save till you can afford the arb deflator
lukes_89
Joined: Fri Sep 25, 2009 11:30 pm Posts: 1204 Location: sunshine coast
 Posted: Sat Jan 08, 2011 10:13 pm |
the best thing i spent 50cents on was at supercrap on there cheap little compressors you plug into your car, the little flip valve that locks it onto your wheel you can buy them seperatley. all you do is clip it on and it lets the air out of your tyres i use mine up the beach they are great and really cheap you can buy 4 of them for $2
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3459 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Sat Jan 08, 2011 11:35 pm |
Go to your local tyre store and ask for one of these and a few spare valve cores. Then you can unscrew the valve and let the tyre down quickly. Its just a valve cap that screws on where your standard cap goes.
price free
_________________ Camels have nice toes
4x4ish
Joined: Sun Jun 24, 2007 11:30 pm Posts: 752 Location: Brisbane
 Posted: Mon Jan 10, 2011 7:24 am |
SuziBlu wrote: What about ya ignition key.
exactly what i was thinking.
ando_zook94
Joined: Sun May 09, 2010 9:23 pm Posts: 263 Location: brissy
 Posted: Mon Jan 10, 2011 8:42 am |
The back of the tyre gauge from super cheap, cost me $1 . Check ya pressure, then turn it round and it's it a circle with a small pin, let's air our rapidly  . Cheapest option besides ur stick solution or ignition key
_________________ If in doubt power out!
sickzuk1
 Posted: Mon Jan 10, 2011 9:09 am |
I think I will go with ando_zook94's idea. I do have a little pressure gauge. But no pin thingy on the other side. I think I will just stick one to it
Glavas
Joined: Thu May 06, 2010 2:13 pm Posts: 322 Location: Adelaide
 Posted: Mon Jan 10, 2011 10:33 am |
Those little pressure gauges have a minimum of 15 - 20 PSI don't they?
turbo_deo
Joined: Mon Oct 11, 2010 5:14 am Posts: 542 Location: Newcastle
Vehicle: Work van
 Posted: Tue Jan 11, 2011 1:48 am |
After using a arb deflator I wouldn't use anything else, best 55 bucks I err spent
_________________ Swb softie spoa cromo front -50 beadlocks 6.5s
sickzuk1
 Posted: Tue Jan 11, 2011 2:33 am |
Nah mine goes all the way down to 5 PSI. Tested it on my mums flat tyre
stocker
Joined: Wed Dec 08, 2010 7:16 am Posts: 941 Location: Shidoni!
 Posted: Tue Jan 11, 2011 2:36 am |
 You can get the Staun Tyre deflators for 50bucks on ebay... they seem to work just fine for me
_________________ Stocker
squizzytaylor
Joined: Sat Sep 26, 2009 11:30 pm Posts: 381 Location: Bogged near Morisset
 Posted: Tue Jan 11, 2011 2:38 am |
turbo_deo wrote: After using a arb deflator I wouldn't use anything else, best 55 bucks I err spent
X2 these are the best thing since muff.
RIKSTR
Joined: Sun Apr 26, 2009 11:30 pm Posts: 1278 Location: Canberra
 Posted: Tue Jan 11, 2011 3:46 am |
