| Author |
Message |
skelaaleks
Joined: Wed Jun 09, 2010 8:31 am Posts: 237 Location: brissy
 Posted: Tue Jan 11, 2011 8:06 am |
Hey I was wondering what you guys have done for removable doors. A dodgy way I can see is to cut off the top part of the standard door hindge as well as the pin that would normally be located in that part.
Does this work?
Also I am guessing the answer is no. But is it legal to drive a 92 Sierra without doors? I know you can with some older 4x4's.
Just havent been able to talk to the transport department about it yet
atari4x4
 Posted: Tue Jan 11, 2011 8:24 am |
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Tue Jan 11, 2011 8:27 am |
Like these
LAY80N
Joined: Tue Jul 28, 2009 11:30 pm Posts: 455 Location: Newcastle NSW
Vehicle: I drive your mum
 Posted: Tue Jan 11, 2011 8:28 am |
skelaaleks wrote: Hey I was wondering what you guys have done for removable doors. A dodgy way I can see is to cut off the top part of the standard door hindge as well as the pin that would normally be located in that part.
Does this work?
Also I am guessing the answer is no. But is it legal to drive a 92 Sierra without doors? I know you can with some older 4x4's. Just havent been able to talk to the transport department about it yet
Cutting the top section of the hindge off so they are just pins that can drop the door onto them is pretty common and works fine.
Layto....
skelaaleks
 Posted: Tue Jan 11, 2011 9:30 am |
Cool I
Didn't Even think that the mirrors are on the doors
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Jan 11, 2011 9:23 pm |
LAY80N wrote: Cutting the top section of the hindge off so they are just pins that can drop the door onto them is pretty common and works fine.
Layto....
Works fine until you roll it and open your door to have it FALL OFF.
LAY80N
 Posted: Wed Jan 12, 2011 4:15 am |
want33s wrote: LAY80N wrote: Cutting the top section of the hindge off so they are just pins that can drop the door onto them is pretty common and works fine.
Layto....
Hahahaha good point, i had half doors on so can just climb out.
Layto....
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Wed Jan 12, 2011 5:59 am |
LAY80N wrote: want33s wrote: LAY80N wrote: Cutting the top section of the hindge off so they are just pins that can drop the door onto them is pretty common and works fine.
Layto....
Works fine until you roll it and open your door to have it FALL OFF. Hahahaha good point, i had half doors on so can just climb out. Layto....
Cut off the very top that stops the door coming off and replace it with a split pin? I should go have a look at my doors and see if that would be viable.
atari4x4
 Posted: Wed Jan 12, 2011 6:04 am |
Layto....
speaking from experience?
want33s
 Posted: Wed Jan 12, 2011 6:26 am |
atari4x4 wrote: speaking from experience?
Nah never been silly enough to want to wheel without doors... Lantana sucks.
Fatzook
 Posted: Wed Jan 12, 2011 6:32 am |
want33s wrote: atari4x4 wrote: speaking from experience?  Nah never been silly enough to want to wheel without doors... Lantana sucks.
AIm for rocks then
I remember a time at Rover park when Steve was egging me on to drive Fatzook up a big rock shelf (1.5m) with a deep crevice up the middle. He told me that he had done it last time, and that I would be fine. So I got the front end up, then the back started climbing, and when I almost got to the top, the drivers side dropped in and I was wedged.
Then He said ' Yeah that happened to me too'  Could have killed him
mika
Vehicle: Sierra
 Posted: Wed Jan 12, 2011 6:36 am |
I'm pretty certain it's not legal to drive a sierra with no doors as they aren't designed to be removed like on a jeep wrangler. Also, AFAIK new side intrusion laws come in in July 1997 meaning even wranglers with a compliance plate post july 1997 cannot legally drive without doors.
Having said that if you are pulled over for no doors I'd just say that they are designed to be removed and it's completely legal to drive without them
Fatzook
 Posted: Wed Jan 12, 2011 6:43 am |
mika wrote: I'm pretty certain it's not legal to drive a sierra with no doors as they aren't designed to be removed like on a jeep wrangler. Also, AFAIK new side intrusion laws come in in July 1997 meaning even wranglers with a compliance plate post july 1997 cannot legally drive without doors. Having said that if you are pulled over for no doors I'd just say that they are designed to be removed and it's completely legal to drive without them
Yeah sierras aren't supposed to have the doors removed, but they also predate side intrusion laws, so its a grey area. Only the coilys have SIB in the doors I believe, allthough I have never actually seen one.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13016 Location: Melbourne
 Posted: Wed Jan 12, 2011 7:37 am |
Sierra doors are designed to be removed and in a pre 1997 car there's no side intrusion requirement so a pre '97 sierra is legal with the doors off so long so long as it has mirrors.
Just the same is it's legal to drive a sierra with the windscreen folded (or removed)
This is the word from Dotars. (Canberra) On paper, when requested by a club member here in Victoria. (Mika - Greg, in case you were wondering, and his car hasn't seen doors for years)
If the States, or your local cop interpret the rules differently, there's really nothing you can do.
Personally, I've been pulled over without doors on by my local cop (who is a good bloke) who believed me when I said it was legal, but his comment was that TOG (a traffic cop) might have a different view and issue a canary, and there would be nothing I could do about it. Fair call.
We've also been pulled over as a group by TOG, and they've written "notice to fix" notes for all of our cars for tyres/mudflaps etc, but a couple of us weren't running doors and it wasn't mentioned.
It's the luck of the draw. If you have an otherwise legal car, and have mirrors, I don't think it's a problem.
Qld is Qld though. Not sure I'd do it up there. Not sure I'd drive a 4WD though either in QLD, seems like too much hassle
Fatzook
 Posted: Wed Jan 12, 2011 7:51 am |
Gwagensteve wrote: Qld is Qld though. Not sure I'd do it up there. Not sure I'd drive a 4WD though either in QLD, seems like too much hassle  Steve.
Its worth it. More diverse terrain than just mud  Although with all the rain we've seen lately it would be dryer in melbourne
mika
Vehicle: Sierra
 Posted: Wed Jan 12, 2011 7:57 am |
If sierra doors were designed to be removed they didn't do a very good job! My jeep doors take 2 seconds to remove but my sierra doors, well unless you like driving around with hinges rattling around or have a grinder handy I can't see how you are going to remove them very quickly. Those screws that attach the hinges to the body are almost impossible to get out.
I'm guessing your supposed to put up with the hinges, they probably thought people wouldn't notice them over all the other rattles in a sierra
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Wed Jan 12, 2011 8:01 am |
i've always wanted to go doorless in mine for the increased field of view - the one time i tried i couldnt get the hinger screws undone so i gave up. lol
I've also got speakers in my doors which i'd need to make disconnects on the wiring, so that again made me less inclined.
Perhaps once TSOR is back in action fatzook can make us some proper sliding hinges so we dont have to hack our factory ones to bits? =)
Fatzook
 Posted: Wed Jan 12, 2011 8:13 am |
I used to run doorless all the time.
The extra visability gives you gbs more confidence on side angles.
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Wed Jan 12, 2011 8:32 am |
Fatzook wrote: I used to run doorless all the time. The extra visability gives you gbs more confidence on side angles.
Who is that kid driving Fatzook
_________________ Shep is a closet jimny lover!!!!
Fatzook
 Posted: Wed Jan 12, 2011 8:48 am |
Dunno but I've got 5 yrs and 20 kg on him
Rusho
 Posted: Wed Jan 12, 2011 8:53 am |
mika
Vehicle: Sierra
 Posted: Wed Jan 12, 2011 9:36 am |
that's a nice sierra fatzook. tyres look like swampers, what size? Is that running coils?
sorry for the thread hi-jack.
Fatzook
 Posted: Wed Jan 12, 2011 10:35 am |
Yeah its long gone now. Parted it out years ago.
They were 36" TSL's. V6 crummydore motorand auto, Bundy diffs, coil front, Coilovers in the rear, 75 series transfer. Went alright offroad and in the mud drags.
Gwagensteve
 Posted: Wed Jan 12, 2011 7:18 pm |
mika wrote: Those screws that attach the hinges to the body are almost impossible to get out. I'm guessing your supposed to put up with the hinges, they probably thought people wouldn't notice them over all the other rattles in a sierra
Use a cold chisel on the edge of the screw to crack them. (i.e hit down at the 12 O'clock position to make a notch in the screw then roll the chisel to 45 degrees and tap away to crack the paint.
It's never failed me and takes seconds.
It will/might make a bit of a mess of the screw. Just clean them up with a bench grinder, or replace them with bolts.
Cut hinges are hack IMHO, and milled aluminium cut hinges are shiny hack (and a terrible idea - a stainless pin in a aluminium hole  )
I will add, I don't run doorless anymore - I run 1/2 doors. All the advantages of doorless, but with better side impact protection than a stock door (let alone doorless) door seals that still work, and stuff stays in the car. Also, with a hollowed out door, an enormous storage pocket in each door.
PS Mika - you should try folding the windcreen in a sierra on a car that's never been apart - getting the screws undone that tie the door top bars to the screen and B pillar is a nightmare- but only the first time.
