It is currently Tue Nov 03, 2026 3:34 am
Vehicle: 1987 sierra tray back buggy
Post Posted: Sat Jan 15, 2011 3:18 am
Fellas i did a search but i couldnt find the threads i have seen before.
basically same old story 4 low is popping out / wont stay in when not under load seams like the gear stick hits the body before it is all the way into 4 low. Iv read bout the problem before but cant remember what the cause is help please.
Post Posted: Sat Jan 15, 2011 3:20 am
Body lift? Broken transfer mount?
Post Posted: Sat Jan 15, 2011 3:45 am
na no bl ill check on the transfer mount when it comes back from wedge but i dont think that any are busted.
Post Posted: Sat Jan 15, 2011 4:08 am
G/stick bush......
Vehicle: 75 Cruiser
Post Posted: Sat Jan 15, 2011 4:14 am
The Occy Strap has come off :wink:
Post Posted: Sat Jan 15, 2011 4:28 am
detent?
broken mount?
bush?
hitting floor allthough shoudnt without bl
Post Posted: Sat Jan 15, 2011 6:16 am
grand vitara ? selecta hub if it is between 98 and 2000 modle. common as mud.
If sierra id say mount or what seak_knife said
Suzuki is my way of life.
Post Posted: Sat Jan 15, 2011 7:40 am
x2 for gearstick bush...... exactly what happened on mine fine under load then would pop straight out when you hit the clutch.
Post Posted: Sat Jan 15, 2011 8:22 am
ok so search hasnt given me anything yet either, i have done the 2" body lift and it wont stay in low range, do i just bend the metal out of the way of the gear stick?
Post Posted: Sat Jan 15, 2011 8:24 am
That'll do it.... :)
Post Posted: Sat Jan 15, 2011 8:46 am
sweet thanks fellas ill check those ideas out.
Post Posted: Sun Jan 16, 2011 2:10 am
I did a 50mm lift on a 92 vitara and had to bend both levers. Take levers out and heat and bend
Users browsing this forum: Google [Bot] and 112 guests
