It is currently Tue Nov 03, 2026 7:19 am
Post Posted: Sat Jan 15, 2011 9:00 am
hey guys i went out bago nsw today and my low range jumps out of its gear every time i hit a bump is this normal with a cab lift???????? and how can i fix it
Vehicle: Vitara 90'
Post Posted: Sat Jan 15, 2011 9:01 am
Did you cut some room when you lifted? It's probably hitting on something when the transmision moves.
Post Posted: Sat Jan 15, 2011 9:02 am
there are a couple of active threads on this subject. stick is probably hitting the floorplan
Post Posted: Sat Jan 15, 2011 9:06 am
yes it would be cut out where it is hitting and you may need 2 remove a bit off rubber
if u drive a loud toyota ute u drink rum
Post Posted: Sat Jan 15, 2011 9:10 am
i got under there and it is hitting the tunnel
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Vehicle: Vitara 90'
Post Posted: Sat Jan 15, 2011 9:12 am
Nibler to the rescue!!
Post Posted: Sat Jan 15, 2011 9:17 am
haha yer it gets anoyying after a while trying to hold it in whil 4x4ing lol
Post Posted: Sat Jan 15, 2011 9:30 am
You can always re-bend the shifter lever to suit , but making the hole a little larger usually fixes the problem , Cheers Paul.
Post Posted: Sat Jan 15, 2011 10:30 am
You can also install a tcase lift if you have a body lift already, could be worthwhile.
Post Posted: Sun Jan 16, 2011 12:24 pm
i just lifted my tcase with 3 bits of box section and high tensile bolts once i did my BL, worked a treat and now the tcase is high and dry so i dont hit it the same :)
tintop, barwork, locked Front , RUF, 4.9's, 31's :
Users browsing this forum: No registered users and 81 guests
