It is currently Wed Nov 04, 2026 2:49 pm
Vehicle: Daisy
Post Posted: Fri Jan 14, 2011 2:26 am
Hey all, as the title says, what's the length of the dipstick for a stock engine in a 1990 wt?
If anyone could measure it that would be great, just incase I have some aftermarket shorter dipstick and the engine is only burning oil because the level is too high!
Post Posted: Fri Jan 14, 2011 3:13 am
I'm pretty sure if its a 1990 it'll be a G13BA, mine certainly is... Anyway, I'm at work but I'll measure it when I get home...
The other option is, do an oil and filter change then put 4 litres of fresh oil in it. Then she'll be right.
I want my old sig back :(
Post Posted: Fri Jan 14, 2011 4:47 am
from the bottom of the cap that sits on the tube the dipstick sits in to the curve on the bottom is 352mm mine is a 94 1.3 hope that makes sense
Post Posted: Fri Jan 14, 2011 7:11 am
mine is a 90 model wt and its about 306mm thats just the metal bit
Post Posted: Fri Jan 14, 2011 7:39 am
there are different length dipsticks and dipstick tubes. need to get ones that match.
Vehicle: Daisy
Post Posted: Fri Jan 14, 2011 9:09 am
Thanks lads, I'll go have a look after dinner or in the morning. I just had a mate who was driving behind me on the way home, pull up at the lights beside me to say "I can smell your rings burning there mate!" so I assume the problem is getting worse because you couldn't really smell it before :(
Vehicle: Daisy
Post Posted: Sat Jan 15, 2011 8:16 pm
Ok so it turns out mine is 306mm for just the metal part of the stick. Which from the replies here seems standard.
Bloody thing is worse than a 2 stroke that means, as I've gone from top dot on stick to just touching the stick in half a tank of fuel!
Next time I put fuel in it, I'll top the oil up and then measure the drop and check the km it's done.
Also still trying to decide what engine to put in, I was all excited about a 4age (or a 4agze but I am too poor for that) but now I'm again of two minds. I'll have to bring up all the pages with power/torque figures e.t.c and weigh it up for benifit vs trouble.
EDIT: I do remember having to put in more than the 4 litres of oil when I did the oil change, though a mate of mine who was following me reckoned the smell is horrible from the burning oil, and when I lift off coming down a hill, he could see smoke but from the breather not just the exhaust. If it's coming out the breather it's most definitely rings, I should borrow a compression tester.
Post Posted: Sat Jan 15, 2011 8:33 pm
Vehicle: Zookless
Post Posted: Sun Jan 16, 2011 12:09 am
Does anyone know the correct volume of oil for a G16B with a G13 sump?
I've been using the G16B tube and dip-stick.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 68 guests
