It is currently Fri Jul 31, 2026 1:31 am
Post Posted: Sat Jan 15, 2011 12:00 pm
After having my carb rebuilt I am still having trouble with power.
My poor Vitara won't even get past 90kmh and that's flat on the floor!!!
I have noticed a monster flat spot at 3-4000 rpm and the engine just won't rev past 4000rpm. It feels as though the secondary is opening but the fuel jet is not operating in it and creating a huge lean condition.
So I disconnected the vacuum line for the secondary so it does not operate and now just using the primary it will rev right out in 1-3 gear but still won't get past 90kmh.
So I think it may be a blocked secondary jet. Does this sounds right to you guys? If so how to I fix this?
Any help is much appreciated.
Vehicle: Daisy
Post Posted: Sat Jan 15, 2011 6:58 pm
Rebuild the carby? I'm no expert but if it's giving you that much trouble it might be worth doing.
Post Posted: Sat Jan 15, 2011 10:53 pm
Read the first paragraph of my post... It has just been rebuilt but obviously not so well.
Please anyone out there when specific knowledge on these Carbs.
Post Posted: Sat Jan 15, 2011 10:55 pm
Does it drop dead as soon as the secondary tries to open? Check the connections to the solinoids on the carb. One of the is a fuel bowl vent solinoid. If this aint connected the engine really drops dead
Dan
Lil Foot!
Post Posted: Sat Jan 15, 2011 11:45 pm
JusT looses power. Wouldn't say drops dead.
All vacuum hoses and solinoids are working as intended. I can't beleive that the car runs better with the secondary disconnected! I have been driving around without secondaries for I don't know how long!
Any other ideas?
Vehicle: I drive your mum
Post Posted: Sun Jan 16, 2011 7:05 am
Have you checked the secondary actuation vacuum pot with a mityvac or something to confirm its operating at the correct vacuum level?
Layto....
Post Posted: Sun Jan 16, 2011 9:20 am
Secondary vacuum pot has been confirmed by using vacuum line from inlet manifold. Secondary fully opens just no extra juice :(
Post Posted: Sun Jan 16, 2011 10:27 am
what about air leaks?
Post Posted: Sun Jan 16, 2011 12:00 pm
It runs fine with the secondary disabled via unplugging the vacuum pot. This rules out airleaks.
I may just take the carb apart and learn how the insides work and what's stopping the fuel from passing through tHe secondary jet.
Best way to learn is to do I suppose. I'll keep has updated.
Post Posted: Sun Jan 16, 2011 11:21 pm
Is it a mikuni? Still sounds like a blocked or non working fuel bowl vent solinoid. Its the larger circular one at the top of the carb. Double check its electrical connections or even go as far as wiring 12V directly to it and give that a go.
Lil Foot!
Post Posted: Mon Jan 17, 2011 3:04 am
Will do jrzook. Yes it is a Mikuni.
You don't happen to have a pic laying by any chance of the solenoid?
What is the purpose of this valve? Opens to let air bleed into the bowl for faster fuel delivery? Thanks for your help so far.
I will check it out this arvo.
Post Posted: Tue Jan 18, 2011 6:17 am
pm'd
Post Posted: Thu Jan 20, 2011 9:37 pm
pm'd
Pm'd back. Got it running yet?
Lil Foot!
Users browsing this forum: Google [Bot] and 331 guests
