It is currently Tue Nov 03, 2026 9:15 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2
Post Posted: Sun Jan 16, 2011 8:25 pm
Where can I get them flowed ? Does that clean them also ?
My Maruti build, Click WWW
Post Posted: Sun Jan 16, 2011 8:31 pm
Have you had the cam pulley off it? Even if you haven't Dave may have, and there are 2 ways for it to go back on. If you put in on the wrong way and line up the timing marks the cam timing will be out.
There are some pics and a explanation in this thread.
Post Posted: Sun Jan 16, 2011 10:32 pm
I didn't take it off, I'll find out if he did, cheers
Post Posted: Sun Jan 16, 2011 11:16 pm
Then if its a fueling problem spray some juice down the intake and see if it cranks. If the plugs are out you should be able to turn it over and a mist of fuel should be evident if the injectors are firing.
Lil Foot!
Post Posted: Sun Jan 16, 2011 11:23 pm
x2, if you can see spark unplug the injectors, crank for a bit to clear the manifold and give the intake a spray with fuel to see if it kicks, if nothing you have a timing issue (assuming the engine is sound)
Post Posted: Mon Jan 17, 2011 1:46 am
Ok
Post Posted: Mon Jan 17, 2011 7:26 am
did you try anything today mate
Post Posted: Mon Jan 17, 2011 7:32 am
im new to this whole suzuki thing, and this may be a stupid question.
but if its an auto ecu, have you bridge the neutral start switch?
Post Posted: Mon Jan 17, 2011 7:41 am
No, that will stop the starter kicking in...
Good thinking tho.. :P
Post Posted: Mon Jan 17, 2011 7:45 am
not if hes hard wired the starter...
Post Posted: Mon Jan 17, 2011 7:53 am
But the ecu doesn't care if it's auto or manual, it only care's that it has an eng on the other side of it's wire's, the Tcm will take that part of N switch..
Post Posted: Mon Jan 17, 2011 8:13 am
not on toyotas, theres a NSW pin on the ECU you have to ground, otherwise the engine will do sweet fuck all.
was just a question, in cause suzi was the same!
Post Posted: Mon Jan 17, 2011 8:14 am
http://www.ptjau.com/images/sierra/bale ... ringv1.pdf
have a look... :)
Post Posted: Mon Jan 17, 2011 8:20 am
that pinout if from a manual ECU, i dont see the point your attempting to make?
Post Posted: Mon Jan 17, 2011 8:22 am
I have an auto ECU in my sierra. It did not require me to bridge the neutral start switch for it to run. Once the TCM was removed and all accosiated wiring, it fired first go.
Post Posted: Mon Jan 17, 2011 8:23 am
Post Posted: Mon Jan 17, 2011 8:43 am
Sorry guys, cant try anything till Saturday arvo, I'm at work for the week atm.
cant wait to try the idea's but thanks a lot guys!
Post Posted: Mon Jan 17, 2011 9:08 am
ahhh i dig, the transmission is controlled seperately?
Post Posted: Mon Jan 17, 2011 9:09 am
Bingo :wink: TCM = Transmission Control Module
Post Posted: Tue Jan 18, 2011 8:47 am
any news mate?? find the problem yet
Post Posted: Tue Jan 18, 2011 9:49 am
:roll:
Post Posted: Sat Jan 22, 2011 7:11 pm
Now?? :P
Post Posted: Sat Jan 22, 2011 10:33 pm
Yew put the injectors back in gave them a tap and broom, she fired, thanks guys !!!!!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 77 guests
