It is currently Tue Nov 03, 2026 1:05 pm
Post Posted: Mon Jan 17, 2011 5:12 am
I managed to get water up to the fuel cap on the weekend. This wasn't the first time either. I've tried various fuel caps etc but none seem to seal properly - presumably to vent gases etc. In the interest of keeping water out of the tank, has anyone relocated the fuel filler to the inside of the car? I imagine this would be fairly easy to do by simply disconnecting the hose from the filler pipe, rotate it towards the inside of the car, and connecting it to a new filler pipe with cap (from wreckers). Thoughts?
Cheers,
Jimmy.
Post Posted: Mon Jan 17, 2011 5:15 am
Cheers,
Jimmy.
If it doesn't seal properly and you put it inside the vehicle I can only guess you're gonna get fumes in there. That would suck. Don't light a ciggie.
Post Posted: Mon Jan 17, 2011 6:53 am
just don't worry about it, maybe if it's a current and it's pushing against the fuel side, just drive backwards through the river :D
Vehicle: 2001 M18a Jimny
Post Posted: Tue Jan 18, 2011 9:22 am
I've got a fuel cap that I purchased from repco that seals extremely well. Had to almost force it on. Cept I don't think it vents the pressure.. at all.
http://www.facebook.com/omalleyimagesonline
Post Posted: Tue Jan 18, 2011 9:52 am
i put a ryco marine fuel filter with water seperator and mounted where the carbon canister normally sits. I placed a heat sheild to protect it from the headers.
I bypassed the original fuel filter, and plumbed the marine filter before the fuel pump.
I also installed a motorbike filter between pump and carby, to reduce the chance of gunk coming from the pump.
Post Posted: Tue Jan 18, 2011 9:59 am
Who's talking about filters???? :?
This thread is about the merits relocating the fuel FILLER :lol:
Post Posted: Tue Jan 18, 2011 10:05 am
Ill blame my phone for me being a retard.
But it does solve the water in fuel issue
relocation is due to water ingress, filter mentioned stops said ingressed water getting out of the filter, hence relevant :)
Post Posted: Tue Jan 18, 2011 10:09 am
Ok. How much water can the seperator hold? :lol:
Vehicle: 2018 DMAX
Post Posted: Tue Jan 18, 2011 10:13 am
Then you would get one that stops flowing if there is too much water.. :lol:
Post Posted: Tue Jan 18, 2011 10:16 am
Yeeeeeeeaaaaaah :lol:
Can you bolt on an auxilary tank to the seperator? :lol:
Post Posted: Tue Jan 18, 2011 11:02 am
If you can work out somewhere to fit this where it wont get damaged from rocks and stuff they seal extremely well and dont have a breather. Its a flush mount marine fuel filler, that they use for there onboard fuel tanks.
Post Posted: Wed Jan 19, 2011 10:09 pm
The sping loaded flap in the fuel filler prevents heaps of water pouring into your tank anyway.
Try filling up using a jerry can, and a short funnel which doesnt open this flap. See how long it takes.
Users browsing this forum: Google [Bot] and 95 guests
