It is currently Tue Nov 03, 2026 12:05 pm
Post Posted: Fri Jan 21, 2011 8:11 am
Hi
Another annoying question, I'm trying to bleed my brakes after fitting longer brake lines, with the car off the pedal feels great though the moment I start the car it goes to the floor, now I have done the usual checked for leaks kept bleeding the whole lot, with the car running I pumped the brakes to get a Lil bit of pedal and the engine tries to stall or does stall, can anyone give me some advice on what this could be? Thank you
Post Posted: Fri Jan 21, 2011 9:54 am
Are you still getting air out??
Have you adjusted your rear shoe's lately??
Post Posted: Fri Jan 21, 2011 11:04 am
Doesn't seem to be any air coming out, haven't adjusted shoes for a while
96 coily, lifted, locked,geared, 33's.
DRV31T
Post Posted: Fri Jan 21, 2011 11:10 am
brake booster problem maybe?
If brakes had air in line, pedal would still be bad even with car off.
If starting car causes brake fail, it may be loosing vaccuum, or something?
Vehicle: I drive your mum
Post Posted: Fri Jan 21, 2011 12:39 pm
Sounds like air in the lines.
Layto....
Post Posted: Fri Jan 21, 2011 7:18 pm
Thanks guys will keep trying to bleed them
DRV31T
Post Posted: Fri Jan 21, 2011 8:41 pm
I often clamp off each individual brake line, and try pedal,
that can tell you where your problem is.
IE front, back, left or right etc
Post Posted: Fri Jan 21, 2011 10:53 pm
Yea just clamped off the two front and it tried to stall clamped the rear and left front it tried to stall swapped sides and still tried to stall ha ha so might try something else now, thanks for the advice but
DRV31T
Post Posted: Fri Jan 21, 2011 10:54 pm
Sounds like a vacuum problem cause the moment I pump the break pedal it tries to stall
DRV31T
Post Posted: Fri Jan 21, 2011 10:57 pm
That is what I think, too.
Buggered or loose lines,
Blocked vac line,
booster may need a service.
Post Posted: Fri Jan 21, 2011 11:09 pm
Yea guess I will play around with it later on, hopefully nothing to major :)
DRV31T
Post Posted: Sat Jan 22, 2011 10:55 am
And still no win, pain in the arse brakes...
DRV31T
Post Posted: Sat Jan 22, 2011 6:48 pm
With the eng off, if you pump the brake's 3-5 time's does the peddle come good??
If yes, adjust rear brake's....
Post Posted: Sun Jan 23, 2011 3:22 am
Still no good, just going to pay someone to come have a look. Thanks guys
DRV31T
Post Posted: Sun Jan 23, 2011 4:09 am
dont bleed the brakes with the engine running, you can tear the booster and cause vacuum issues
Post Posted: Sun Jan 23, 2011 5:20 am
Thanks for the heads up, I have bled the brakes soooo much two full bottles of brake fluid and still no pedal and stalling engine, all I done was change the rear brake line to a extended one and the front right, and the left is different again which is typical of a coily. Will try and see what else it can be
DRV31T
Post Posted: Sun Jan 23, 2011 6:27 am
Getting a quiet squeak noise from around the brake booster very quiet but...
DRV31T
Post Posted: Mon Jan 24, 2011 6:47 am
Has anybody ever had the problem when they have installed extended brake lines that the booster isn't pimping enough fluid to the brakes? I'm now going to remove the extended brake line put back in standard lines and see if it changes, have gone over everything so that's my new option
DRV31T
Users browsing this forum: Google [Bot] and 112 guests
