It is currently Mon Nov 02, 2026 9:16 pm
Vehicle: Vitara 90'
Post Posted: Thu Jan 20, 2011 6:53 am
Hey Guys,
Just have my cars in bits, I've got a million different greases but was unsure what to use in this bit??
Also I'm guessing the screw on bit that covers the bearings shouldn't be less than finger tight?
Vehicle: 1.6 SJ80
Post Posted: Thu Jan 20, 2011 6:59 am
Bearing grease mate.
Any general purpose grease would be fine. I like to use Marine grade on my hubs, just incase a little moisture gets in.
Vehicle: Vitara 90'
Sweet, I was thinking that but wasn't sure. :D
Post Posted: Thu Jan 20, 2011 7:52 am
no, bearing grease :) general purpose can mean anything, even pig fat
and no the nut shouldn't be finger tight, bearings probably flogged :)
Vehicle: Vitara 90'
Post Posted: Thu Jan 20, 2011 7:58 am
Bearings didn't have any movement in them, I've never noticed the movement before. I'll see how it goes once it's all back together and driving.
I used HTB grease, I wasn't sure if maybe I should have had to use Moly grease or just bearing grease.
If all else fails, I'll just PM weaves :D
Post Posted: Thu Jan 20, 2011 10:24 am
Better whip down to Maccas and get a sunday then :wink:
Post Posted: Fri Jan 21, 2011 8:39 am
just putting a swivel hub kit through mine now..my bearing nuts were loose as well..but my inside bearing was just a handful of metal completly shot..how tight should they be according to the book..I just cranked them up tight then backed them off so the wheel spins easy..plus my axle seals and king pin bearings were on there last legs as well..all fixed now though .
Post Posted: Fri Jan 21, 2011 5:55 pm
grease for wheel bearings with disc brakes needs to be high temp. type grease.
Users browsing this forum: No registered users and 477 guests
