It is currently Tue Nov 03, 2026 12:21 pm
Post Posted: Sat Jan 22, 2011 12:52 am
Hi All :)
I have another wee prob with my 89 Samurai. It's making a tapping sound when driving. I reset the valve lash and thought that may have solved the problem but it hasn't. It's quite a loudish noise, hence why I thought it may have been the tappets.
It doesn't make the noise when the engine is idling or if your not accelerating. I cant possible think what it may be. I havn't notice any decrease in engine performance or anything.
Thanks,
Grunta
Post Posted: Sat Jan 22, 2011 12:55 am
what sort of fuel are you running through it? if it's low grade you could be suffering from "pinging" pre ignition of the fuel.
have you checked and replaced the basics like timing, spark plugs, dizzy cap & leads?
Post Posted: Sat Jan 22, 2011 1:00 am
grunta wrote:
Hi All :)
Thanks,
Grunta
Mine does it too, but only when cold. Runningon 98 too 8O
Post Posted: Sat Jan 22, 2011 1:06 am
crickey, bloody quick replys :D
It's not pinging as that was an issue I had awhile ago and solved that problem. It's got new plugs in it as well so it's not the plugs. I can rev the engine and the noise isn't there, but when driving it is. It has to be engine related though because when accelerating (not hard) it's there. But i can be cruising and it's not there. :?:
I'm running 95 through caltex
Vehicle: Daisy
Post Posted: Sat Jan 22, 2011 1:08 am
I have a whine from my gearbox, and an occasional noisy tappet, Is it really hectic like something's loose/broken or is it just like something is louder than normal?
Post Posted: Sat Jan 22, 2011 1:13 am
Not sure if it's something broken. I don't think so because as stated about it's not there if i'm just cruising at "x" km/h but if i put it under abit of load it starts making the noise. If I have the engine idling and rev it - no noise. I'm thinking about putting the vehicle up on axle stands and getting someone to drive it through the gears and see if i can see where it's coming from
Post Posted: Sat Jan 22, 2011 1:54 am
i had a similar sounding noise which ended up being a missing rocker shaft retaining thingo screw
Post Posted: Sat Jan 22, 2011 4:42 am
Could even be an exhaust leak..
Post Posted: Sat Jan 22, 2011 4:53 am
mine made an aweful tapping noise when the cam pulley let go
Post Posted: Sat Jan 22, 2011 5:10 am
I hope the cam pulley is not about to go! :( The thing that confues me is that it's not a constant noise - and i'm going to sound like a broken record here :lol: but it's only when accelerating. I could be going 60km/h and just just have enough pressure on the gas to stay at 60km/h and no noise.
Vehicle: LJ20 LJ50
Post Posted: Sat Jan 22, 2011 5:12 am
hole in exhaust or blown exhaust manifold gasket
Camels have nice toes
Vehicle: 105 landcruiser
Post Posted: Sat Jan 22, 2011 5:36 am
I had a similar noise .. was a broken piston skirt on number 4
Vehicle: I drive your mum
Post Posted: Sat Jan 22, 2011 3:36 pm
Can you post a video of the noise up?
Im thinking along the same lines ot TZAR here, if it only does it on acceleration check your exhaust manifold/gasket.
Layto....
Post Posted: Sat Jan 22, 2011 4:32 pm
I'll try and get one this morning.
Post Posted: Sat Jan 22, 2011 7:31 pm
here is a link to a video.
http://s821.photobucket.com/albums/zz13 ... ant030.mp4
Thanks guys
Vehicle: Daisy
Post Posted: Sat Jan 22, 2011 7:34 pm
That's a horrible bloody tapping noise!
NFI what it is though!
Post Posted: Sat Jan 22, 2011 7:37 pm
very much so! :( i just hope it's nothing too major really.
Vehicle: '85 SJ413 LWB Ute
Post Posted: Sat Jan 22, 2011 8:41 pm
Sounds like a exhaust manifold/gasket leak...
Post Posted: Sat Jan 22, 2011 9:26 pm
cool, i hope it is just that. When i brought the vehicle it had a leak between the gasket and exhaust manifold and the guy re did it, but I can't remember if it's the same noise or not. The engine runs fine - as far as i know with these vehicles. Would i need a new gasket or can I clean up the old one a re glue it? Just out of interest how easily do these vehicles rev? I feel taking it up to 3 1/5 to 4k seems enough as it doesn't feel like your getting much more go out of it and it's not as a toyota 1300 which revs easy to 6-7k.
Thanks guys for your input :D
Post Posted: Sat Jan 22, 2011 9:53 pm
:P Easy!!!!! :P
Rev it, they like it.. :P 8)
Users browsing this forum: Google [Bot] and 99 guests
