It is currently Tue Nov 03, 2026 12:45 pm
Vehicle: 2007 Suzuki Grand Vitara
Post Posted: Mon Jan 24, 2011 11:26 am
i bought an opensky awning for the side of my car the other day.
ive got rola roof racks to mount them on, the 4wd shop i bought the awning from suggested that i just drill L brackets into the roof racks and mount it on that... i'm going to use the L bracket idea, except find another way to mount the l brackets to the roof racks, i dont really want to drill into the rack.
anybody got any ideas (and or pictures) to mount the L brackets to the roof rack?
Christian
2007 Suzuki GV 2.7ltr V6
Post Posted: Mon Jan 24, 2011 11:33 am
do the rola racks have a track down the middle of the cross bars?
I used that.
Post Posted: Mon Jan 24, 2011 11:37 am
yeah they do, although mine has a rubber strip down the middle covering the track. i guess i can cut it up if needed. did you just use t headed bolts
i.e http://www.rola.com.au/prodimages/inst_279_s_l.jpg
can you buy these from bunnings or the like?
Post Posted: Mon Jan 24, 2011 11:39 am
http://www.rhinorack.com.au/AccSubCateg ... 04_35.aspx
I have a sports rola rack and used the fittings above. had to grind them a tiny bit to them them fit. but that only took 10 secs on a angel grinder.
was unable to find the proper rola rack ones but i'm sure they make them.
Post Posted: Mon Jan 24, 2011 11:41 am
haha yeah you can take that strip out, trim it up and slide it back in.
the local store for rola in my town are pathetic... that's why i use rhino ones
Post Posted: Mon Jan 24, 2011 11:51 am
cool. did you just bend up your own L brackets?
Post Posted: Mon Jan 24, 2011 12:53 pm
these are the rola ones for the sports racks.
http://www.rola.com.au/trade-accessories.aspx
Post Posted: Mon Jan 24, 2011 9:51 pm
Geez they ain't cheap!!! 8O
2002 SWB GV
Lifted and Locked
Post Posted: Mon Jan 24, 2011 11:15 pm
nah a set came with the awning.
and the price is also a reason I didn't use rola ones
Vehicle: Yamaha scooter, 50cc
Post Posted: Tue Jan 25, 2011 1:25 am
You can pull the rubber strip out and use a couple of uni strut nuts inside the rack to hold the L bracket onto the rack, that's how I mounted mine. I also mine with the L turned down over the end of the rack rather than up, so that the awning wasn't sticking way up in the air
Post Posted: Tue Jan 25, 2011 4:20 am
yeah i was planning on mounting it downwards.
might go visit bunnings first then see i i can get some bolts that fit in the track
cheers
Post Posted: Tue Jan 25, 2011 5:12 am
Yeah bunnings have cheap brackets, i used some L-shaped brackets on my awning. Although i doubt you could use them like i have because you have rola.
I was able to bolt them in the channel, where you cant see it.
Post Posted: Wed Jan 26, 2011 11:26 pm
thanks for the help!
ended up get a 100x100x40 bracket, some washers and nylon lock nuts from bunnings, went over the road to autoone( or was it pro) whom sold thule bars, thule do this kit for mounting some of thier stuff, turn out its been made to be compatible with other types of bars (including rola).
was able to mount the brackets downwards without it fowling on the door.
anywhos its now sitting on the side of my car.
cheers all
Christian
Users browsing this forum: No registered users and 103 guests
