It is currently Fri Jul 31, 2026 2:17 am
Post Posted: Sun Jan 23, 2011 2:15 am
just wondering if there is such a thing as a standard rear swaybar on a zook, i had a nt 1ltr lwb a few years ago and it had what looked to be a factory fitted rear sway bar setup, but i have never heard of any others having it
Post Posted: Sun Jan 23, 2011 2:49 am
Katana's have rear sway bars and the Katana are 2wd version of a sierra.
Post Posted: Sun Jan 23, 2011 10:45 am
Yep. My 84 LWB styleside had one. And I believe that Whiteline have aftermaket rear swaybars for LWB sierras.
Post Posted: Mon Jan 24, 2011 4:13 am
Yes, Styleside 1.0 LWB's had rear factory swaybars.
Not sure why you'd want a swaybar in the rear of a sierra though, they already have plenty of rear roll stiffness.
Post Posted: Mon Jan 24, 2011 6:58 am
They drift REALLY well on the dirt :wink:
Post Posted: Mon Jan 24, 2011 8:17 am
I suppose i could modify a front setup for the rear, they were pretty similar from memory.
Post Posted: Mon Jan 24, 2011 8:42 am
Front WT won't work. I tried.
A front NT is closer, but still not wide enough IMO.
Post Posted: Mon Jan 24, 2011 8:43 am
does it really need a rear swaybar??? i wouldnt have thought the rear would move much at all once you took the 3/4 epiliptic out?
Post Posted: Mon Jan 24, 2011 8:47 am
My 93sierra lwb had a rear sway bar factory fitted, but no front.
It took up space in my garage for 13 or so years, now its at a scrap steel merchant, probably being made into a new car
Post Posted: Mon Jan 24, 2011 9:22 am
just playing with a few idea's at the moment to get some tune-ability in the suspension setup within the production class 7 rules for the offroad racing it makes it hard competing with newer coilsprung cars i know its more about the experience for many others but finishing ahead of some of the larger 4bys would make it worth while for me.
Post Posted: Mon Jan 24, 2011 9:25 am
what about a stiffer spring and softer shock? add an extra main leaf and run double rear shocks, but really soft ones?
i reckon the corrugations in racing would fatigue the swaybar mounts or the swaybar itself pretty quickly anyway =)
Post Posted: Mon Jan 24, 2011 1:28 pm
Front WT is pretty close to fitting the back of an LJ50 8O (close enough to make it happen :P ).
Clearance Hole Technology :P
Post Posted: Mon Jan 24, 2011 1:47 pm
I reckon if you fitted a sway bar thats atcually designed for offroad use then you wouldn't have an issue.
Currie - AntiRock
Post Posted: Mon Jan 24, 2011 9:11 pm
I will be running similar to the currie on my coil conversion.
Will be hunting for some torsion bars soon from a lux or nav etc
Post Posted: Mon Jan 24, 2011 9:38 pm
Currie - AntiRock
touche =)
Post Posted: Mon Jan 24, 2011 10:16 pm
Are they splined both ends?
Post Posted: Mon Jan 24, 2011 10:21 pm
what?
Post Posted: Mon Jan 24, 2011 10:31 pm
Should be though have never actually looked at one, ever. Doing abit of research at the moment of what i can use and make etc.
Users browsing this forum: Google [Bot] and 370 guests
