It is currently Fri Jul 31, 2026 2:47 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Tue Jan 25, 2011 12:55 am
Just Wondering what everyone on here deflates to when going offroad
Post Posted: Tue Jan 25, 2011 12:57 am
with out beadlocks, probably no less than 10,
depends on the terrain your driving and the tyres you have though
9 -10 in my vit 5-6 and the Sierra with 31 treps
depends.
What size you running? I have 30's deflate to about 8 psi offroad with rocks etc, about 12 ish on beach work
Post Posted: Tue Jan 25, 2011 12:59 am
Normally, straight to 10psi on any terrain... Let a bit more out if I need to later...
I want my old sig back :(
Post Posted: Tue Jan 25, 2011 1:13 am
Yer I'm running 30s Shitty alterain Do use kno what's a good tyre to run
Post Posted: Tue Jan 25, 2011 1:35 am
go down to 20 ish at seem to bag out good well maxxis
all depends on what ur doing
Post Posted: Tue Jan 25, 2011 1:48 am
20??
I run that on the road!
Post Posted: Tue Jan 25, 2011 2:10 am
20??
eh i run 30 on road lol 10 off lol
well maby run 15 psi hahah
Post Posted: Tue Jan 25, 2011 2:31 am
I deflated mine to 3 yesterday. 5 was still too much.
Vehicle: '96 LWB trayback
Post Posted: Tue Jan 25, 2011 2:36 am
I'll often run 3 on the beach. Any more and I'll struggle on the bigger dunes.
I can fully remove the valve core and still be 100% driveable. The silverstones really are that stiff.
Post Posted: Tue Jan 25, 2011 2:48 am
under 5psi for everything
7psi all the time except on dry sand then i will pretty much let all the air out.
Post Posted: Tue Jan 25, 2011 2:56 am
7 PSI WITH MAXXIS
Post Posted: Tue Jan 25, 2011 3:48 am
Bighorns?
Post Posted: Tue Jan 25, 2011 4:30 am
Zooknoob wrote:
Bighorns?
its something you really need to figure out yourself.
it depends on tyre size , radial or bais ply and what you intend to drive and how fast.
10 -14 might be a safe starting place offroad, and go down from there if your not happy with the traction your getting
Post Posted: Tue Jan 25, 2011 4:33 am
ive got 30inch coopers str's on my coily.
what should i be running on the road?
ive been driving with about 28psi but the car seems to bounce around a fair bit. should i lower my psi
Post Posted: Tue Jan 25, 2011 4:42 am
i would think about 20 ish should be enough
Vehicle: I drive your mum
Post Posted: Tue Jan 25, 2011 4:57 am
2psi :wink:
Layto....
Post Posted: Tue Jan 25, 2011 5:24 am
31x10.5 BFG KM2 - rocks - 10psi all round, bags out HEAPS - enough that i let all the air out of a rear tyre because it was so deformed on a rock.
31x10.5 Simex ET - rocks - 5psi, hardly bagged out at all.
Post Posted: Tue Jan 25, 2011 9:03 am
In my GV I have 10 ply-rated tyres so on dirt 16psi, sand 10psi. Even then it doesn't bag very much. I think I could run down to 5psi if I was careful with my steering.
2002 SWB GV
Lifted and Locked
Post Posted: Tue Jan 25, 2011 9:04 am
Same with my Bighorn's at the Powerlines last time I was there...
Got a bead full of dirt and rocks too :(
Post Posted: Tue Jan 25, 2011 11:35 am
my beeds are sikaflexed on. i run 4psi now
Post Posted: Tue Jan 25, 2011 11:38 am
30" cooper stt's on my coily, 5-10 on the beach 10-12 most other places and 25 on the road seems to work well for me.
Richo
97 Coily 2" susp lift 2" body lift + more
Post Posted: Wed Jan 26, 2011 3:24 am
9-10 for high speed bumpy roads, 6lbs for crawling (BFG/MT 33x12.50's)
Although usually at the end of the run I only have 2lbs left and bark in the bead :rofl:
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Wed Jan 26, 2011 1:14 pm
50 kpa
I have issues
What are you looking at
Vehicle: Jeep
Post Posted: Thu Jan 27, 2011 2:09 pm
TryHard wrote:
20??
8O 30psi is way to much, i dont run that in my GV, at 30psi in a Sierra it must rattle the teeth in your mouth its so hard 8O
22 to 24psi is all you need in a Sierra for road... 10 psi is good for offroad... :wink: :lol:
Vehicle: Jeep
Post Posted: Thu Jan 27, 2011 2:20 pm
I have Maxxis 6ply LT AT's on my GV, and i find the sidewalls a bit stiff, i normally go down to 14psi for everything, but on my last sand trip, i didnt get bogged and it didnt struggle at all, but i think i would have got further if i was down to 11 or 12psi, so will try that next time, because of the stiffer sidewall... :wink:
Post Posted: Thu Jan 27, 2011 3:16 pm
Yeah on the road I run like 22 in the front max, and like 20-18 in the rear unless I am carrying a load.
I keep the front a little higher because of engine weight, and I like a stiffer sidewall for cornering on the road.
I was used to big cars and 35 psi all the time, but found that even 2 will knock my teeth out in the Sierra.
I run the 6-8 Lbs off road because of the terrain we have here. We have slippery rocks embedded in dirt that has a 2" layer of slimy sticky mud. \
Users browsing this forum: Google [Bot] and 427 guests
