It is currently Fri Jul 31, 2026 1:39 am
Vehicle: My12 Defender 90
Post Posted: Wed Jan 26, 2011 8:47 am
Okay so Ive been trolling the forum for a while punching the search button for an hour. . . still haven't really found the info im after.
I want to lift my new vitara by 50mm. So far i can find 30mm springs and 40mm springs. no 50mm springs. ive also had a look and am thinking a full 2" kit would be great. with new control arms and so forth to keep everything done right.
I know there is a clamini 2" kit. I also understand this does not fit the SV420.
what is the best option to lift my new SV420 by 50mm without using spring spacers! or a body lift. and keep its city drive ability and still take it on some hard days out once a month or so.
also I plan on getting a winch bar (when TSOR releaser one for the SV420) and place a 9000lb or so winch behind it which i know weighs about 35-40kg's how will this affect the level of the car? will i loose a lot of the 50mm lift I am trying to achieve?
I hope that make sense.
Post Posted: Wed Jan 26, 2011 8:49 am
http://auszookers.com/index.php?name=Fo ... ic&t=18541
:P
have a look at atari4X4's build to..
Post Posted: Wed Jan 26, 2011 8:53 am
Ive read Atari's build 10000000000000million times and cant seem to read it enough times.
so the suspension in the 620 is the same as the 420?
Post Posted: Wed Jan 26, 2011 9:12 am
May have different spring & strut rate's but same same. just shorter..
Spring's & shock's, can be done on the cheap by using Gv spring's & a strut top flip, longer rear shock's.
Am told the Gv strut's fit, but the valving IMO would be to stiff for the poor lil thing's...
Post Posted: Wed Jan 26, 2011 10:24 am
AlteredEgo.... come on, some buy this kit already!!!
Post Posted: Wed Jan 26, 2011 9:13 pm
I think that 4.5" is a little much for me. . . 3" would be more than I want to go. . . although there springs look nice. . .
if I can find some 2" springs. do i need to use diff drop brackets? or new lower controll arms? I know I will need new struts and shocks. but is that all?
Post Posted: Wed Jan 26, 2011 10:55 pm
The winch idea from my experience from chopping and changing bullbars so often to do with weight and handling is to mount a towbar tongue in my bar under my number plate and make the winch portable to keep the weight down and the winch in good nic. I am however still exploring the idea to make sure its strong enough as i use the car for a daily driver and still do enough silly things to warrant having it. The warn i was looking about is about 40kg. On the front of a zook for handling is not fun on either the suspension of breaks throwing it around the corner its it is fixed mount.
Post Posted: Wed Jan 26, 2011 10:59 pm
ok :wink:
Post Posted: Thu Jan 27, 2011 7:35 am
ok :wink:
I want a vit just to try it out... :P
Post Posted: Thu Jan 27, 2011 7:51 am
ok :wink:
I'm thinking ATARI version 3.0
Post Posted: Thu Jan 27, 2011 8:30 am
ok :wink:
i have been offered a stupid amount of cash for my sierra and i think i would like to build a 4 door vit. :wink:
Post Posted: Thu Jan 27, 2011 8:32 am
ok :wink:
8O sell that shit heap.
ok :wink:
wierdo poof nancy boy :roll:
Post Posted: Thu Jan 27, 2011 8:55 am
ok :wink:
haha i said vit not jeep. :wink: i think it would mean that i would have to wash
and wear clean clothes without holes. oh and no more #1 haircuts.
oh and start to masturbate like a 14yo again.
thats how it works isn't it atari? :lol:
Post Posted: Thu Jan 27, 2011 9:03 am
yep you'll have to wash at least once a week... i'm running a #3 hair cut & batting off like a 14yo never gets old Armsup
Users browsing this forum: No registered users and 343 guests
