It is currently Wed Nov 04, 2026 11:17 am
Post Posted: Fri Jan 28, 2011 6:54 am
well finaly got 1 installed and it looks really dodgy doe's any1 know if this is how they are ment 2 look
and this is my frist time trying 2 put pics up so if it doe's not work i will repost
if u drive a loud toyota ute u drink rum
Post Posted: Fri Jan 28, 2011 6:56 am
with my vit i used the coil spacer then the original rubber to locate the spring
Post Posted: Fri Jan 28, 2011 6:59 am
do u mean spacer rubber then coil on mine it looks like if i did it that way the coil would just slip to the side
Post Posted: Fri Jan 28, 2011 8:05 am
tomsbum's on the money, there is a rubber seat in the top of the spring thingy, peel it out, fit dodgy lift & then put the rubber on, but they can still slip, hence the dodge part..
Post Posted: Fri Jan 28, 2011 8:57 am
On my Vit rear, I needed a bumpstop spacer, to stop spring moving sideways,
after a 50mm coil spacer lift.
Front was plenty long enuff,
but I added a bumpstop spacer for other reasons
Post Posted: Fri Jan 28, 2011 8:59 am
Post Posted: Fri Jan 28, 2011 7:41 pm
all those spacers are dodgy as. they should have the spring locators made into them so the spring cant move around. have a look at the buget 2" lit spacer on low range for a vitara. i have a set in my vitara and just set for another set for the new one.
Post Posted: Fri Jan 28, 2011 8:27 pm
It does make sense to me, but maybe somebody knows better.
Users browsing this forum: Google [Bot] and 95 guests
