It is currently Tue Nov 03, 2026 11:00 am
Vehicle: Suzukiless these days..
Post Posted: Fri Jan 28, 2011 9:03 am
looking for some advice, just fitted up an iron man lift kit, bout 50mm lift, any way, looking at the two front springs they seem to have a bit of a ben to them when at rest.. are extended coild or any coils on the front of a vit suposed to have a slight bend in them,
Also on the drivers side of the transfer case there is a round alloy thing with a rubber center, is it supposed to be bolted to the transfer case? is it a mount? what size bolt goes through it?
cheers in advance
goddamitmyspacebarsbrokenagain
Post Posted: Fri Jan 28, 2011 9:06 am
pics?
Post Posted: Fri Jan 28, 2011 9:08 am
tommorow. dark now
Post Posted: Fri Jan 28, 2011 9:31 am
Where's Macbear when ya need him? :roll:
Post Posted: Fri Jan 28, 2011 9:34 am
he shoots.... and he scores :lol:
Post Posted: Fri Jan 28, 2011 11:01 am
A bend like this?
This is ok, if thats what you meant.
Vehicle: Daisy
Post Posted: Fri Jan 28, 2011 11:02 am
I read that as MacGyver!
Post Posted: Fri Jan 28, 2011 11:03 am
ha exactly like that.....................
Post Posted: Fri Jan 28, 2011 11:04 am
what about the transfer case, strange thing next to it?????? its just a mount bush isnt it? anyidea on the size bolt that goes through
I just watched that today...in its hey day was brilliant.
A bit lame now, but good for nostalgics
Post Posted: Fri Jan 28, 2011 11:06 am
no idea sorry. maybe tomorrow will all be clearer.
dark outside here too :D
Post Posted: Fri Jan 28, 2011 11:08 am
mmm. think I might get a service manual tommorow.... instead of guessing and hitting with a BFH when things dont work.
Post Posted: Fri Jan 28, 2011 11:11 am
As a long term zook owner/driver
I have learnt to carry a BFH as part of the normal travel tools :lol:
Manual is a wise investment.
Post Posted: Fri Jan 28, 2011 11:42 am
it sounds like it's a NVH dampener Greg, sort of looks like an engine/gearbox mount? there is only 1 transfer mount & thats on the bottom of the case on cross member.
Post Posted: Fri Jan 28, 2011 12:51 pm
should have a bolt through it though shouldnt it?
Post Posted: Fri Jan 28, 2011 1:16 pm
You're not a real Zook driver til you've hit something with a BFH on the side of a track in the middle of nowhere ;)
I want my old sig back :(
Post Posted: Fri Jan 28, 2011 1:25 pm
where is it on the transfercase? if it's not attached to the crossmember & case i'd saw it's a NVH dampener.
Post Posted: Fri Jan 28, 2011 1:27 pm
its actually next to transfer case, a seperate round alloy thing woth a rubber center.. 1 earth wire attached to it and thats it
Vehicle: Jeep
Post Posted: Fri Jan 28, 2011 6:12 pm
Ha Ha Ha... i am here, just watchin whats being said here... see if any, and what amount of BS gets dribbled, or if gregwatkins75's question actually gets answered...
Yes the Bow/Bend in the coil, like in christover1's pic, is perfectly normal...
So how do you find the Ironman Suspension ?
As for the other inquiry, will need a pic to see what you are referring too... :D
Post Posted: Fri Jan 28, 2011 6:55 pm
i think it is a mount i seen it the other day on my chassis sitting under the house haven't looked at my car to see whether it is connected. i just went and looked for you no time to take picks but it does have a bolt through it. 2 bolts go through the tcase mount and another bracket bolts to the tcase with 2 bolts then one goes through the round bit looked like about a 10 or 12mm socket.
Users browsing this forum: Google [Bot] and 83 guests
