It is currently Tue Nov 03, 2026 3:11 pm
Post Posted: Fri Jan 28, 2011 9:43 pm
just wondering if any one has put electronic thermo fan on their suzuki sierra
Post Posted: Fri Jan 28, 2011 9:45 pm
yep i have :wink:
Post Posted: Fri Jan 28, 2011 9:57 pm
more info?
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Fri Jan 28, 2011 10:33 pm
stiky wrote:
more info?
What info are you chasing mate?
Size? 14"
Brand? Repco special :roll: (unsure of the actual brand name)
Mounting? I used to little mounting arms and rubbers supplied with the fan then tech screwed them to the bracket on the side of the radiator
Wiring? I have mine set up on a relay and a switch on the dash so it can be switched off for water crossings. Then have a temperature switch so thermo will only come on when engine starts to get above running temperature
temp switch? the switch i have is an adjustable thermo switch, takes a little bit of playing around with to get temps right but i find it works ok once set up corectly.
Reliability? Mine has only let me down twice and both times were due to water getting in the crappy fuse holder supplied with the thermo fan, changed it to a water proof holder and hasn't let me down since.
Post Posted: Fri Jan 28, 2011 11:50 pm
stiky wrote:
more info?
i answered ya question :wink: :lol: what do you want to know?
Post Posted: Sat Jan 29, 2011 3:02 am
good answer shep an rhino thanks mate so it was an aftermarket 14'' what was the cost aprox?
Vehicle: LJ20 LJ50
Post Posted: Sat Jan 29, 2011 4:03 am
tell us why you would want one or think you need one?????
Engine fan is the best idea. Thats why them suzuki engineers put one on your car......
Camels have nice toes
Post Posted: Sat Jan 29, 2011 6:23 am
the 1.6 doesnt line up with the radiator it runs at 175 farenheight does that sound hot?
Post Posted: Sat Jan 29, 2011 6:24 am
i only have an aftermarket temp gauge that works
Post Posted: Sat Jan 29, 2011 7:26 am
175 deg far is only 80 deg cel the thermistst should not open until 82 deg cel. not hot at all
Suzuki is my way of life.
Post Posted: Sat Jan 29, 2011 8:18 am
thanks your spot on i can hear the wine of the fan kick in wen it goes past te 175 mark i am jst worring about shit all
Post Posted: Sat Jan 29, 2011 9:19 pm
electric fans dont like mud....
Post Posted: Sat Jan 29, 2011 9:29 pm
daisy wrote:
cheap electric fans dont like mud....
fixed it for ya :lol:
Post Posted: Sat Jan 29, 2011 11:53 pm
I found one from a wreckers- on the ground but it possibly came from a camry? Perfect fit, shroud went to the edge of radiator. Sucks way more air than the supercheap aftermarket one...
Post Posted: Sun Jan 30, 2011 12:03 am
Fitted a single thermo with shroud (choped to suit) from an AU Falcon to mine, controlled with an adjustable temp switch. Seems to work ok.
Vehicle: 4wd
Post Posted: Sun Jan 30, 2011 12:46 am
Why doesn't the 1.6 line up with the radiator?
Watch out or you'll get sued.
Post Posted: Mon Jan 31, 2011 3:18 am
it simply doest i dont know why does any1 else line up ?
Post Posted: Mon Jan 31, 2011 3:21 am
what did you do for engine mounts? my g16 fitted perfectly. :wink:
Vehicle: 4wd
Post Posted: Mon Jan 31, 2011 3:22 am
Well heaps of people are running the standard fan including myself so I guess so.
Users browsing this forum: Google Adsense [Bot] and 88 guests
