It is currently Fri Jul 31, 2026 9:42 am
Post Posted: Mon Jan 31, 2011 9:24 am
Hey guys i am still having trouble with my wiring: Every time i turn the head lights on i blow my interior fuses so radio, clock, dash lights and door lights. i have replaced the radio rewired the radio harness and even had an auto electrician look at the radio and rewire the earth.
So is there any thing else that could make the fuses blow? Its not the radio so any ideas?
Post Posted: Mon Jan 31, 2011 9:26 am
assuming the earth for the radio isnt wired to teh dash lights youve got a short somewhere, probably in teh tail light loom
you dont really have a choice but to start isolating bits of loom till you find it
Post Posted: Mon Jan 31, 2011 9:33 am
Does it blow with headlights or park lights on?
Post Posted: Mon Jan 31, 2011 9:41 am
headlights on
Post Posted: Mon Jan 31, 2011 9:44 am
umm can i test it by disconnecting circuits for example by removing the clock, or the door lights or the tail lights?
Post Posted: Mon Jan 31, 2011 10:04 am
Also can wiring into the cigarette lighter cause fuses to blow? i have some neons on a switch wired into the cig lighter
Post Posted: Mon Jan 31, 2011 10:07 am
yes and yes
if it only blows on headlights, IE the second click of the headlight switch, try flicking it to high beam first and then turning on, will narrow it down a bit
Post Posted: Mon Jan 31, 2011 10:33 am
okies well i tested cig lighter and its not the neons or cig lighter and yes its second click i shall try high beams when i get more fuses haha
Post Posted: Mon Jan 31, 2011 11:03 am
Ah, I had this same problem a month ago. I wired a stereo up and connected it to a wire that the multimeter said was an earth.
Everytime I turned on my headlights it would blow the fuse. If you have just put in a stereo (or something else) try using another earth.
edit- just reread your post, does it do it if you disconnect the stereo earth altogether?
Post Posted: Mon Jan 31, 2011 11:56 am
i shall check in the morning thanks man that might be it.
Post Posted: Tue Feb 01, 2011 5:16 am
I dont think its the earth. I have replaced it
Users browsing this forum: Google [Bot] and 401 guests
