It is currently Fri Jul 31, 2026 9:58 am
Post Posted: Tue Feb 01, 2011 7:45 am
i have a 96 coily sierra need some longer shocks due to the spacer's i put in now when i go over bumb's i can fell them full going out and stoping i've seen broken radius arms on coily sierra from to much flex so how big can i go till there is a chance of brakeing something
if u drive a loud toyota ute u drink rum
Post Posted: Tue Feb 01, 2011 7:49 am
im thinking 3 inch longer or is this to long
Post Posted: Tue Feb 01, 2011 7:52 am
there are the ultima shocks that are apparently a 40mm lift. as far as i know this is the highest you can go without any other problems.
Post Posted: Tue Feb 01, 2011 8:00 am
yer i have the ultima kit in it now and and im only after rear front doe's not seem to bad
Post Posted: Tue Feb 01, 2011 8:06 am
If you only need the rears, measure the current ones and find a replacement that is an inch bigger :wink:
Post Posted: Tue Feb 01, 2011 8:15 am
yer but if i run 3inch shocks will that put to much stress on the radius arms and make then bend or brake under flex
Post Posted: Tue Feb 01, 2011 8:17 am
Depends on what and where you wheel. I'd say braving mounts wouldn't be a bad idea and see how that goes. Your only other option is custom corm arms
Post Posted: Tue Feb 01, 2011 9:23 am
get some longer ones on the rear, and let me know how you go, so i know whether or not to do it also ;)
Post Posted: Tue Feb 01, 2011 9:32 am
will do
Users browsing this forum: No registered users and 384 guests
