It is currently Wed Oct 21, 2026 12:21 pm
Post Posted: Wed Jun 25, 2008 2:25 am
is there any one on here running one of these engines? can you bolt them up to a 1.3 ltr 5 speed?
just been reading about them and want to know how there go as it would be easer than 4ag i'm looking to do because they bolt up to 1 ltr ( my car is a 1 ltr) mounts.
Post Posted: Wed Jun 25, 2008 2:38 am
ive driven an F6A sierra, it was shithouse, absolute shithouse
and they are closer to 1.3 mounts than 1 litre anyway
Post Posted: Wed Jun 25, 2008 12:05 pm
Easiest way to do it would be to get a front cut, all the bits should just bolt straight in. I've never driven one though, so can't comment on the performance.
There is nothing straight forward about a 4A swap, as everything has to be fabricated. And as Pubic will attest to, T50 transmissions are not the easiest things to find. I've driven a 4A powered Sierra though, it went like a stabbed rat :D
Post Posted: Wed Jun 25, 2008 9:32 pm
i was reading about a few cars with these engines and got me thinking would be easyer than a 4ag but if they are shit to drive i'll go with the 4ag.
i know there is nothing straight forward with the swap. i'll have to do engine, gear box, radiator monuts, loom wiring,jack shaft, fuel pump and exhaust. is there anything else i need yo know before i go get the engine>
do i have to mod the trans tunnel to fit the box in a 1 ltr body?
Post Posted: Wed Jun 25, 2008 10:31 pm
Not that I can think of, bit i've never done a 4AG swap! You're bound to come across a few things that you didn't think of, you'll just have to sort those as you go.
I don't recall my mate's zook having any tunnel mods, but don't take that as gospel.
What engine are you looking at getting?
Post Posted: Wed Jun 25, 2008 10:40 pm
f6?....what.....someone wants a golfcart?....... :roll: ummmm...hard to get parts........would be better suited to a chainsaw.....
Post Posted: Wed Jun 25, 2008 11:51 pm
a sierra is about the same size as a golf cart so maybe thats why people like the engine.
i'm looking to get a engine out of a 89- 90's corolla. there are a few cars anound here for about $200. one has a dead head gasket and the other needs new rings. the engine has to come out any way so might as well fix a gasket or rings while it is and i get the loom.
now just have to track down a t50 out of a 76 celica and away i go.
Post Posted: Thu Jun 26, 2008 2:17 am
Yes, the F6A will bolt in on 1.0 mounts and no, it shouldn't be shithouse unless there were issues that needed addressing. Having driven one I would put it as better than a 1.6 carby and I have a K6A going in to mine which is better again but good luck trying to find either a F6A or K6A.
Post Posted: Thu Jun 26, 2008 2:18 am
Oh and parts aren't hard to get at all.
Post Posted: Fri Aug 21, 2009 1:47 am
I presume you'd be wanting an F6A Turbo, not N/A? The F6A Turbo in Japanese Jimnys put out as much power as a G13B, but with less torque. There are more that a couple of Cappucinos getting around with the F8B block with the F6A-T head and ancilliaries that really honk along.
All F blocks F8A(LJ80, SK80 Carry), F10A(1.0lt Sierra, Super Carry) (4 cyls), F5A(Mighty Boy, Alto), F6A(Alto), F6A-T(Cappucino) and F8B(Hatch) (3 cyls) all have the same bellhousing pattern, clutch style, and Rad connections to make the swap possible.
I'd love to put a hybrid F8B/F6A-T into an LJ80!
Post Posted: Fri Aug 21, 2009 2:06 am
T18 5spd the same to. tunnel stay`s std , clutch goe`s hyd, have to try to get that beside the booster ( thats why i throu mine in the bin )
How fast do you want to go??
Post Posted: Fri Aug 21, 2009 5:51 pm
this is a grave dig, i never found a usable engine that was under $1000 so it got caned.
i'll be going turbo 1.3 again in my car i have now.
Post Posted: Sat Aug 22, 2009 1:58 am
toyota 5k, 1500cc. 7k 1800 multi point inj torque ALL day & still rev, out of lite ace van`s, 5sd out of ke30 to ke50, cable clutch, lite ace box can be used but the shifter is cable.
EDIT: & thay don`t come in at 3.5 tonne, mine was VERY front heavy, found myself on the front bar more than once.
Steve
Users browsing this forum: Google Adsense [Bot] and 120 guests
