It is currently Mon Oct 19, 2026 7:26 pm
Post Posted: Mon Jul 07, 2008 2:27 pm
Hi All
I have just found that the front end trailing arms on my coily aren't straight. The deflection (bow) is about 3-6mm from straight. Is this something to consider, as in replacing them or leave well enough alone. The car is still steering straight and ther's no obvious signs of tyre wear.
Any feed back would be appreciated.
Mark
Post Posted: Fri Jul 11, 2008 10:08 pm
Go get some spare ones from the wreckers anyway. If you use it off road, it's only a matter of time before you make the bend worse or snap one. They aren't to difficult to change.
When asking, ask for Jimny ones and not SJ80. Most just seem to get confused when asking for Coil Sierra ones and give an outright No in response to having any. The are essentially identical.
In saying that, mine are probably bent about the same.
Vehicle: 75 Cruiser
Post Posted: Fri Jul 11, 2008 11:26 pm
heh, i know some one who asked a spring place if they could supply some lifted coils, and they said Suzuki never made a Coil Sierra :lol:
Post Posted: Sat Jul 12, 2008 12:21 am
Probably wouldn't hurt to have your alignment checked out though if it's a Daily Driver, although it may drive straight, if it's out it could cause unnecessary tyre wear. I don't drive mine enough to care whether it's out or not.
I have been asked on more then one occassion on who did my coil conversion. Probably doesn't help that i have a 1L front and Santana badges on it.
Users browsing this forum: No registered users and 266 guests
