It is currently Wed Nov 04, 2026 6:39 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Thu Feb 24, 2011 5:01 am
hey guys
my zook is using a full tank of premium to about 250 ks maximum. this sounds way to high to me. i drive it like a grandma to haha. im thinking i should stop into th one stopp zuki shop and get a tune up or is there a better option to try improve the economy?
any help will be appretiated
Post Posted: Thu Feb 24, 2011 5:02 am
What sort of mods does it have?
I want my old sig back :(
Vehicle: Daisy
Post Posted: Thu Feb 24, 2011 5:08 am
Where did you end up getting the zook from? Did you get that one that was at oxenford?
Post Posted: Thu Feb 24, 2011 5:23 am
that is about what mine gets
Post Posted: Thu Feb 24, 2011 5:26 am
I'd be pissed off if I only got 350k's.
Get it sorted .....oil is now $100 a barrel
bye
Post Posted: Thu Feb 24, 2011 5:33 am
What model, what size donk, what mods, what speed.
250 is pretty low.
Open road, I get about 10 liters per 100 kilometers, is in essence, I should, from full to dead empty, get 400k, never dun that but.
When out playing, struth, well less than half that.
Post Posted: Thu Feb 24, 2011 5:53 am
bye
Yep and now a carbon tax is looming from the lying redhead its gonna cost a shitload more :roll:
Post Posted: Thu Feb 24, 2011 6:04 am
it's hard to tell exacly: speedo, odo and tachometer don't work properly. however, i estimate fuel consumption at about 11-12 l / 100km for a 1.6 vit carby engine in my sierra, i wish i had a efi :)
Vehicle: LPG 1.6 Sierra
Post Posted: Thu Feb 24, 2011 6:33 am
Suckers. Costs me $7 to do 100ks in mine, maybe $8 on a bad day.
Post Posted: Thu Feb 24, 2011 6:47 am
just redone my carby and i'm getting 8.9L/100k from my old 1.3 carby motor :D
Post Posted: Thu Feb 24, 2011 7:12 am
sounds like the choke isnt coming off.
Post Posted: Thu Feb 24, 2011 7:36 am
At $1.36, average, that means you are getting around 5 liters per hundred kilometers, by crikey, tell ya what, dont tell the fuel companys, they will be out hunting you with a dirty great big gun.
What are you driving, a prius. No way on earth would a 4wd brick, get that, even if dropped from a helicopter with the engine turned off, gathering ks.
Post Posted: Thu Feb 24, 2011 7:45 am
He's on gas (LPG)
Post Posted: Thu Feb 24, 2011 7:57 am
DOH
Post Posted: Thu Feb 24, 2011 8:06 am
Awww, I wanted to stir. Ha ha :)
Since the K&N filter, exhaust install, LPG retune, and new oils everywhere I reckon 100km = about 10.5L of LPG. I'm spewing LPG was 60c in december, but I gotta pay 68c now... it used to cost me $6/100kms :cry:
Post Posted: Thu Feb 24, 2011 8:36 am
Still can't complain although the initial setup woulda cost a chunk
Post Posted: Fri Feb 25, 2011 12:55 am
thanks for your help guys.
its just a stock as a rock 98 Coily.
nar tercius it was a bit to expensive for me and i got my coily for $1000 cheaper =)
i dont think i would often go over quarter throttle. i just didnt think it sounded right that a 1.3 zook would use $50 of petrol to 250ks =S
Post Posted: Fri Feb 25, 2011 12:57 am
In my experience with high consumption its usually to do with incorrect float heights in the carb, or a dirty air filter.
Give the carb a good clean out and reset the float to factory and give it another shot.
Post Posted: Fri Feb 25, 2011 1:19 am
drive it hard and see how ya go. try to keep the revs around 4000 and see if your economy improves.
sierras have a little revy motor and they dont like being driven like a diesel 4wd.
Post Posted: Fri Feb 25, 2011 1:48 am
how do you reset the floats to factory?ive got the cleaning bit sorted but you have got me at the floats haha. alright shep i will give that a go haha cheers mate
Vehicle: Daisy
Post Posted: Fri Feb 25, 2011 1:56 am
I bloody knew I shoulda been flogging the thing!
Pity it blows smoke on the changes when I go too hard :(
I did just bolt my original engine to the engine stand ready to start taking apart though!
Post Posted: Fri Feb 25, 2011 2:09 am
So its not the one in you're avatar then...
Hmm if its stock you should be seeing a bit more... Try what shep says, also a good tune up may not go amiss...
Post Posted: Fri Feb 25, 2011 3:05 am
nar thats my mates coily. alot of travel for a 2 inch suspension and body lift hey =P im doing the same mods to mine when i get the time.
alright will give it more juice and i will get back to you guys =)
Post Posted: Fri Feb 25, 2011 3:25 am
how much fuel are you getting into a tank?
Post Posted: Fri Feb 25, 2011 3:35 am
Check if the choke flap is full open once its warmed up. Does it run sweet?
Lil Foot!
Vehicle: LWB Sierra
Post Posted: Fri Feb 25, 2011 4:25 am
I think i have petrol issues too then...
I have LWB sierra
1.5 toyota 5k engine
31x10.5 tyres
the usual 2" lift and 2"BL
everything else is pretty much normal.
I'm getting 200 - 220kms per tank?!?
Prior to my carby rebuild i was getting around 180 so i thought this was an improvement? do you think it can be anything else?
Will the fuel pump/fuel filter play a part in this?
Cheers.
Andrew
Post Posted: Fri Feb 25, 2011 4:27 am
are you not running transfer gears, on 31s? there might be your answer
^^ have you done anything to correct the speedo, are those 200-220kms going off the odometer or gps?
Post Posted: Fri Feb 25, 2011 4:30 am
I have LWB sierra
31x10.5 tyres
Cheers.
Andrew
if you have 31" tyres with stock gearing you will never get good fuel consumption.
it is the same as if i put 38" tyres on my toyota and expected there to be good fuel consumption.
also because the speedo will be around 20% out, 100km on your odo is really 120km.
Post Posted: Fri Feb 25, 2011 4:44 am
You can't expect too much from an old carby engine.
I'm getting 270k's to a tank with a big dent in it.
Thats with 32's x 10.5's, 6.5's and 1.6 carb motor.
Users browsing this forum: No registered users and 172 guests
