It is currently Wed Jul 22, 2026 4:07 pm
Post Posted: Sun Jul 13, 2008 6:29 am
g'day all
My name is jeremy. I have a hardtop 93 WT.
It has:50mm snake racing shackles
2'' dobinsons leaves
(soon to have- 50mm body lift)
Now i was asking wat would be the best sized tyre?
(width and height) I already know i want muddies but not sure wat size will be the best for this application,the best for flex and also that will fill the guards well-with minimal scrubbage..
cheers
lesspostingmorewheeling
Post Posted: Sun Jul 13, 2008 6:35 am
i've got 31x10s on my WT but thats with a 75mm lift and 30mm higher springs i don't have scrubbing problems but you might need to hammer down the lip just in the guards
Post Posted: Sun Jul 13, 2008 6:52 am
awesome,i wanted 31's.haha do they flex up ok??
Post Posted: Sun Jul 13, 2008 6:59 am
a zook dosen't look right with anything less than 30s :wink:
i just remembered that the front bumper mounts had to be cut off to fit the tyres
yeah it flexs alright it still bottoms out on the bumpstops but i've only got shit springs at the moment you can get a ramp under one of the front wheels and the opposite back one but i think thats pretty standard
Post Posted: Sun Jul 13, 2008 7:49 am
haha definitly!!!
yer i had to cut mine off 2
"you can get a ramp under one of the front wheels and the opposite back one but i think thats pretty standard" wat do you mean??
Post Posted: Sun Jul 13, 2008 1:44 pm
wat would be the max tyre size that would fit??
Post Posted: Sun Jul 13, 2008 5:43 pm
you know those ramps you drive your car on the work underneath and shit
the diffs can hit the bumpstops without rubbing
Post Posted: Mon Jul 14, 2008 2:25 am
would 31's be the max tyre size with only springs,shackels,b/l -all 2"??
Post Posted: Mon Jul 14, 2008 2:28 am
i'm sure people have don't it but i couldn't fit any bigger on mine
Post Posted: Mon Jul 14, 2008 3:55 am
people have gone 33's with the same amount but i think a bit more hammering was addministered
Post Posted: Mon Jul 14, 2008 3:58 am
Suzy (bluesuzy) has 33 with 2inch spring and a 2inch BL but i think he did a bit of work inside the guards
i have 1inch spring and 3inch BL and the lip inside the guard had to be "massaged"
Post Posted: Mon Jul 14, 2008 2:41 pm
motorway have 31' retread mongrels but 32' monotread..what one would be better?would the 32's fit??
Post Posted: Mon Jul 14, 2008 6:22 pm
if the 33's fit with a bit of guard reconstruction you might find that the 32's will still hit without persuading the guard to get the hell out of there
Post Posted: Mon Jul 14, 2008 11:04 pm
the monoform 32x10.5 would be best, if you move your front diff forward you'd have less of a chance of them rubbing
Post Posted: Tue Jul 15, 2008 5:12 am
and to move the diff forward you jus re-drill the hole on the u-bolt plate ay?
Post Posted: Tue Jul 15, 2008 5:24 am
the 32" mongrels really only measure 31". I ran them with 2" springs and 2" BL without moving the diff forward. All that was needed was a bit of hammering in the guards.
When i went to 32" BFG muddies which actually measure 32", i had to move the front diff 1" forward and do a bit more guard massaging
you need to redrill the sring mount on the diff too, if you want a bit of lift and some more flex stick some rear springs in the front this will help with moving the diff too
Post Posted: Tue Jul 15, 2008 1:06 pm
kool guys thanx for the help!!!
Post Posted: Fri Jul 18, 2008 2:32 am
do you think i would be able to fit 33' mtr's?
Post Posted: Fri Jul 18, 2008 2:36 am
more work again but same procedure. If need be move the diff if not bash those guards
Post Posted: Fri Jul 18, 2008 2:37 am
Post Posted: Mon Jul 28, 2008 2:38 pm
dont worry bout the 33s jez, theyre gone anyways......hehehe
Post Posted: Mon Jul 28, 2008 8:28 pm
stock gearing with 33's is going to be a piece of poo to drive...Slooow on road...Way too fast offroad, Ask norm how he went the other week with me and zooker..
Users browsing this forum: Google [Bot] and 233 guests
