It is currently Wed Nov 04, 2026 9:47 am
Post Posted: Thu Feb 24, 2011 8:01 am
My temp gauge is up the shit its a shitty OLD aftermarket one am going to replace it i am pretty sure its water temp as there is 2 little nipple looking thing coming out of the thermostat case to a wire will this be the senser or whataver reads the temp ?
Post Posted: Thu Feb 24, 2011 8:17 am
The temp gauge is the nipple with one wire.....
Post Posted: Thu Feb 24, 2011 8:23 am
sweet cheers do u know if the cheaper gauges are acurate?
Post Posted: Thu Feb 24, 2011 8:28 am
Yes, no, they are shit..
Nothing wrong with the std one, just get a new sender...
Post Posted: Thu Feb 24, 2011 8:30 am
the standard one hasnt been hooked up since the engine conversion there is a shitty aftermarket one hooked up wich i am replacing just trying to wokr out if i need to spend 100 bucks or 50
Post Posted: Thu Feb 24, 2011 8:48 am
Sierra with 1.6??
use a std sierra sender in the 1.6 with the factory gauge, unless you spend big coin, after market gauge's are shit..
Post Posted: Thu Feb 24, 2011 8:52 am
Is there anyway to get the baleno motor temp to work on Sierra gauge ?
My Maruti build, Click WWW
i will have to try work out whhy it aint working at the moment are the standard electric?
Post Posted: Thu Feb 24, 2011 8:56 am
Yep..
steak_knife wrote:
Sierra with 1.6??
Let the car harness do oil & temp, the ecu doesn't need those two, the ecu has it's own CTS (coolant temp sen) which is the nipple with 2 wire's..
EDIT!! just looked at a wiring dia for a baleno eng, it has a 3 pin CTS & feed's the cluster from that.
Post Posted: Thu Feb 24, 2011 9:05 am
im lost
Post Posted: Thu Feb 24, 2011 9:14 am
stiky wrote:
im lost
get a Gps... :P
What eng did you put in, & a sierra yes??
Vehicle: Sierra Utey!
Post Posted: Thu Feb 24, 2011 9:21 am
You're confusing the man Steve...
My ute..
Post Posted: Thu Feb 24, 2011 9:25 am
thanx...... :D
Post Posted: Thu Feb 24, 2011 9:37 am
Sorta this thread.
My lwb reads really low on the guage at operating tempreture, always has.
I've put a new sender in, had change of dash.still reads at bottom of guage...Works but,I have boiled it once,and guage when right up.
Someone once told me the guage and sender have to have the same resistant?????. I've pulled the wire off the sender and earthed it, and the guage goes right up..
I'd be great to have it reading in the middle like the other old serria's.
bye
Post Posted: Thu Feb 24, 2011 10:31 am
I'll be one to chuck the silly questions out there...
Does it have a thermostat installed?
Does the heater work as in hot air coming out?
I have had a couple of my and mates cars thermostats seizing open.
This of course would cause your temp gauge to read low.
Post Posted: Thu Feb 24, 2011 10:46 am
Good one, i'll check that in theam...thanks
bye
Post Posted: Thu Feb 24, 2011 8:08 pm
steak_knife wrote:
stiky wrote:
im lost
get a Gps... :P
What eng did you put in, & a sierra yes??[/quote
G16b in a sierra
Users browsing this forum: Google [Bot] and 146 guests
