It is currently Wed Nov 04, 2026 4:15 am
Post Posted: Sun Feb 27, 2011 5:05 am
Hit a snag with the build the other day. Was swinging a locked centre into another housing from one of my previous wrecks, all roughly the same age, all 1.6, all manual. But there wasnt the same number of bolts going into the ring gear to just swap the centre across :? . Both rings and pinion from each diff have the same number and teeth. Cant remember the number of teeth off the top of my head, just remember they where the same on each.
Woundering if they are the same gearing? Or if there is a definite way of diagnosing the gearing. Just want to be sure before i go dropping it back into the housing.
Post Posted: Sun Feb 27, 2011 5:12 am
There are 10 & 12 bolt crown wheels available for the rear of the Vitara's, from memory the carby swb's had the 10 bolt crown wheels.
The tooth count should be 41/8= 5.125.
Post Posted: Sun Feb 27, 2011 5:18 am
cheers atari. Yep, and that was the count too. Just threw me off completely having that difference in bolt numbers.
Users browsing this forum: Google Adsense [Bot] and 80 guests
