It is currently Thu Nov 05, 2026 10:26 pm
Post Posted: Fri Feb 25, 2011 4:46 am
Steak_knife will love this question.
Suzisport sell Jimny castor correction bushes and I sent an email to find out if the were adjustable as my castor is slightly out due to a 40mm OME lift and I want to go back to factory settings and since I am replacing other bushes and fitting a stabilizer I thought I might as well get them done at the same time. Suzisport replied to my email that they are fully adjustable but before I fork out almost $200 I thought I ask first if anyone else has had them and how did they find them.
Cheers, Paul
Post Posted: Fri Feb 25, 2011 6:51 am
I asked them e-mailed them about there bushs, and they couldn't even tell me how much off-set the bushs had.
I think the bushs on this page would be better
http://www.4wd1.com/Jimny.htm#suspension
Vehicle: Currently vehicle-less
Post Posted: Fri Feb 25, 2011 7:10 am
I fitted the suzisport ones in my jimny.
They are 2 degrees and are basically a 2-piece poly bush, with a non-adjustable metal sleeve that slots in.
You have to push the poly bush parts in from either side of the arm(with grease) and slot the metal sleeve in the inside.
Very easy to fit - I was pretty happy with mine.
Post Posted: Fri Feb 25, 2011 8:40 am
Hmmm, they told me that they are fully adjustable but if they are a two degree correction castor then they not what I want.
Monkey, had a look at the 4wd1 site but they are 3 degree.
Cheers, Paul
Post Posted: Fri Feb 25, 2011 8:43 am
sorry didn't realize you had a 40mm lift, 2deg bushs should b good for the 40mm lift.
Post Posted: Fri Feb 25, 2011 9:23 am
OK, thought even 2 degree might be too much. Thanks Monkey.
Paul
Post Posted: Fri Feb 25, 2011 9:26 am
No worries mate!
And don't think you will be able to get anything less than 2deg.
Post Posted: Mon Feb 28, 2011 5:27 am
Cheers, Paul
Spoke to Derek from Suzisport and he confirmed that the ones advertised as adjustable are fully adjustable by rotating the metal sleeve.
Paul
Post Posted: Mon Feb 28, 2011 7:17 am
Cheers, Paul
Paul
Yes that sounds about right, i got OL do put mine in so they good get it the same on both sides.
Users browsing this forum: No registered users and 111 guests
