It is currently Fri Jul 31, 2026 12:35 pm
Post Posted: Mon Feb 28, 2011 9:39 am
hey will or does anybody know of anybody that can body lift an 09 jimny?
Post Posted: Mon Feb 28, 2011 9:42 am
you cant due to airbags..
Post Posted: Mon Feb 28, 2011 9:43 am
yer thought that may have been the case :(
Post Posted: Mon Feb 28, 2011 9:46 am
why do you want to body lift?
Post Posted: Mon Feb 28, 2011 9:47 am
umm it was just a surgestion instead of coil spacers.
but i didnt think i could due to airbags.
just need to find some shockies that will fit .
and have around 6-7"
Post Posted: Mon Feb 28, 2011 10:01 am
I read on here the other day, that you can body lift, because jimny's have a airbag system that cab be body lifted....stekky posted it...calling stekky!
Edit: There is a jimny a 2010 jimny in perth That has 80mmlift with 2"Bl running 31's.
Post Posted: Mon Feb 28, 2011 10:35 am
The ruling apparantly is if it's an impact sensor so can not fit a body lift but if it's a G force sensor you can. I'm not sure which the Jimny has.
Post Posted: Mon Feb 28, 2011 10:36 am
90% sure it's G-force.
Post Posted: Mon Feb 28, 2011 10:55 am
u can body lift any thing, just if u have an accident and your in the wrong your screwed,
Monkey is right, there is a white jimny over here on 31 inch claws,
and an 08 black jimny near coffs harbour on 33s
dodgy brothers mechanical
Post Posted: Mon Feb 28, 2011 10:56 am
Chop the guards like kelmar you will need to anyway BL or no BL.
Post Posted: Mon Feb 28, 2011 10:59 am
u cant get much more then a 31 on with out either moving your diff forward a bit or, cutting the floor and re shaping it, like the guys a coffs did
Post Posted: Mon Feb 28, 2011 11:03 am
Don't for get he dose not have any off=set on the rims, so they might just tucked right up under the guard nicley.
Post Posted: Mon Feb 28, 2011 11:05 am
there still gonna hit when the diff comes straigh up
mine where only hitting in a straght line
when it got flexed they were not a problem
just when u hit bums with any momentum
Vehicle: Sj70 tintop
Post Posted: Mon Feb 28, 2011 11:06 am
there was a jimny for sale on carsales ages ago that had 33''s, no bl, minimum work, just cut the fark out the guards, ive always had this idea of throwing hilux axles under a jimny with some coil overs, (than i changed my tampon) hahahah just jokes,
but why dont one of you do that, would be a STABLE weapon and wouldnt take piss all to get approval.
:stekky:
Sj70 tintop
Post Posted: Mon Feb 28, 2011 11:07 am
mine to or when this happens
Post Posted: Mon Feb 28, 2011 11:10 am
there is a jimny over east
with lux diffs and 35s,
the guys are on this forum
Post Posted: Mon Feb 28, 2011 11:11 am
There are jimny in switzland on 37's.
Post Posted: Mon Feb 28, 2011 11:17 am
the only reason i bring it up is, the taller you go the worse it is, the jimny is a light narrow swb and wont handle well when lifted 50'' so you can fit on some 31s. i flipped a 75 series at moderate speed cause it had a high centre of gravity, lucky i didnt kill my mate or me.
its no good having a 4wd that rolls in the off camber maccas parking lot.
hilux diffs, cut the guards and coil overs or 40mm lifted stock and you would be laughing, and if u used stock 40mm stuff, it would be pretty cheap.
:stekky:
Sj70 tintop
Post Posted: Mon Feb 28, 2011 11:19 am
lux diffs would make it even more illegal,
if your going to go to that point,
u would just buy a sierra and build it to run 40s
Post Posted: Mon Feb 28, 2011 11:25 am
takes piss all to get approved for lux diffs, engineers like it instead of 1110'' skyscraper narrow 4wd. and it will be 40mm above standard height (not including the tyres you choose to run) and wider. get some flares, enjoy side angles with the rubber side down.
:stekky:
Sj70 tintop
Users browsing this forum: No registered users and 245 guests
