It is currently Thu Nov 05, 2026 12:03 am
Post Posted: Sat Mar 05, 2011 6:40 am
hey guys look i know theres alot of info on falcon alternators i took my zook one out driled the hole for bracket etc and it seem to foul on the engine mount also it dont seem to line up so u cant adjust the tention on the belt .. i may have the wrong alternator .. but its out of my dads EF falcon it.. its a bosh .108 amp
any info would be great i have done some reading about it but it just seems to confuss me ..
it seems i need to grind into the engine mount .. and some how make it line up so u can ajust the tention
Post Posted: Sat Mar 05, 2011 7:17 am
u need the mitsubitshi 110amp one its off the 6cyl model its been covered a few times on here im sure have u tried searching?
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Sat Mar 05, 2011 7:20 am
TryHard wrote:
hey guys look i know theres alot of info on falcon alternators i took my zook one out driled the hole for bracket etc and it seem to foul on the engine mount also it dont seem to line up so u cant adjust the tention on the belt .. i may have the wrong alternator .. but its out of my dads EF falcon it.. its a bosh .108 ampany info would be great i have done some reading about it but it just seems to confuss me ..
Sorry mate but its a mitsubishi alternator you need not the bosch.
Theres a lot of good info in here
Post Posted: Sat Mar 05, 2011 11:32 am
I am curious if there is a comparable car to the falcon over here. The GM alts we use in the U.S. are big,bulky and honestly I don't care for them at all. However they are about the only well known option for upgrade here.
If you guys know of a comparable car or alternator over here that is higher amp,that would be cool.
Thanks
--Sky
Post Posted: Sat Mar 05, 2011 3:47 pm
Sky - what are you putting the alternator on? A 1.3 or 1.6? Have a look at the 2.5 Grand Vitara or Tracker - I think that's a 95A and should swap in directly on a 1.6, but will probably need a lower bracket for a 1.3.
Post Posted: Sat Mar 05, 2011 6:49 pm
I have a 1.6-8 valve , they have single point injection here.
I didn't know they had such a high rating, I am going to have to check those out. Thanks big time armsup
Vehicle: LJ20 LJ50
Post Posted: Sat Mar 05, 2011 7:17 pm
bmw e36 320i have a 140A alternator
Camels have nice toes
Post Posted: Sat Mar 05, 2011 7:22 pm
Hi Skyman , you could also use the XL7 (102 amp) alt though you will need to do some brackomatry and wiring. :wink:
Post Posted: Sat Mar 05, 2011 7:42 pm
Just my luck, brackomatry and wiring is a specialty of mine, now to find one in the yard aye.
Thanks for that one, we do have the XL7 here, and 102 amps is more than enough for the spots, and winch :D
Post Posted: Sat Mar 05, 2011 11:32 pm
Well thanks guys just as i thought :)
just unluky i guess ?:(
Users browsing this forum: No registered users and 235 guests
