It is currently Thu Nov 05, 2026 1:19 am
Post Posted: Fri Mar 11, 2011 1:44 am
:blink:
I've got a '91 Vitara and the passenger window is stuffed. It used to work (slowly) from the driver's side controls, and only went up with the passenger's control. Now it doesn't work at all. Any ideas?
Cheers, Tim.
Post Posted: Fri Mar 11, 2011 1:47 am
the switches failing is pretty common
the slow part is probably a build up of muck in teh works, cleaning it all (including the chanell the glass runs in) and re lubing it can help a lot
Post Posted: Fri Mar 11, 2011 2:02 am
Cheers Royce,
What would you use to lube it with?
Post Posted: Fri Mar 11, 2011 2:06 am
The metal on metal bits in the door use normal grease, the runner for the glass you can use some graphite powder but I would try it just clean and dry first cause the powder can make a mess of anything that touches it
Post Posted: Fri Mar 11, 2011 2:29 am
Could also be the switches, pull them, give them a clean and a squirt of crc
Users browsing this forum: Google [Bot] and 282 guests
