It is currently Thu Nov 05, 2026 4:41 am
Post Posted: Sat Mar 12, 2011 11:48 am
just need to know roughly whats needed,
will do it all at home,
just need to work out some sort of budjet
cheers guys
Post Posted: Sat Mar 12, 2011 11:54 am
What are you doing it too the LJ?
TSOR sells a perch kit
Doesn't your work do this sort of stuff?
Post Posted: Sat Mar 12, 2011 12:05 pm
yea, but im doing it at home,
i haven done 1 at work to know what to do exactly,
ill get help from the fitter there, he has done several sierras
just want to know, obviously i need drive shafts,
but wat else
dodgy brothers mechanical
Post Posted: Sat Mar 12, 2011 12:39 pm
some sort of hi-steer, longer brake lines, new shock mounts???
Are you doing it to the LJ?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Sat Mar 12, 2011 12:55 pm
You also might need an executor for your will. :crazy:
I had a sprung-over LJ50 many moons ago and it was lethally scary. Wouldn't steer straight on potholed roads, would lift wheels easily (eg if you reached out to one side of the car!), and wrecked uni-joints weekly due to the extreme angles arising from the short wheelbase.
But it looked good!
hi steer, brake lines, shocks, shock hoops, driveshafts, anti-wrap bars... thats about it, but first ask WHY... your LJ will clear 29's easily, and with LJ diffs 29's will be plenty - add a locker front and rear and it will be unstoppable.
Post Posted: Sat Mar 12, 2011 1:37 pm
If you really want to spring over an LJ, look at Kenn's car first:
http://www.auszookers.com/index.php?nam ... pic&t=3682
Notice all the suttle things done to it to make it work?
The low sitting Sierra TC (I'm fairly sure this is done to stop the tailshafts self detonating due to angle), the totally custom built steering arms, and brackets to suit ( so the steering actually works), theres more....allot more done to that car then you may first realise!
Personally I wouldn't have a SPOA LJ for the type of driving I do (I've put mine on its side twice, and its basically just got 31's on a very slightly lifted car). A LWB Sierra I could possibly be convinced of, though I have no use for one. LJ's are easy to flat belly, and this might not give you the clearance, but it'll allow you to skid over crap.
Relocate the exhaust, build a solid bolt on flat belly skid plate and drive it like a chimpanzee on a shitload of crack :P
If you use the right type of crack within a few weeks you'll realise your Jimny is a waste of time, will buy about 14 LJ's, ignore your other sad excuse for a Suzuki, and be amazed at how totally brilliant an LJ is in near stock form :D until you get overtaken by a farm tractor on the highway, and realise this isn't quite where they are brilliant.....lol.
Clearance Hole Technology :P
Vehicle: LJ20 LJ50
Post Posted: Sat Mar 12, 2011 9:00 pm
Smurfkid wrote:
basics needed when doing a spring over
Basically enough intelligence not to do it.
the steering is the problem. z bars are gay and don't work. you will need a custom hi steer and the cause of the short wheel base you will have tailshaft problems.
Read the forum, research what to do and you can make a much more capable car rather than a show pony that is useless.
Camels have nice toes
Post Posted: Sat Mar 12, 2011 9:37 pm
only reason i wanted to do it was so i could run my tractor tires in the mud runs we have over here,
guess ill just put some bigger springs in it,
if i was going to spoa i would put wide track axles under it any way
Vehicle: LJ20 LJ50
Post Posted: Sat Mar 12, 2011 9:41 pm
Just put 300mm shackles in it for the mud runs. Even wt diffs are still going to have steering problems. The steering is expensive to get right, and I will repeat Zbars are extremely gay. Gayer than jonno at the world felching championship.....
Post Posted: Sat Mar 12, 2011 9:42 pm
how big are your tractor tyres? i run 33s with 2 inches of lift. so you dont need spoa i doubt
Post Posted: Sat Mar 12, 2011 9:43 pm
just a 32,
ill have to run spaces but thats not a problem
cheers for the info
Post Posted: Sat Mar 12, 2011 9:48 pm
highway star ran a 31 on an lj with no lift at all.
guard chop it and you will fit your tyres
Post Posted: Sat Mar 12, 2011 9:56 pm
no worries,
ill see wat i can do
Users browsing this forum: No registered users and 708 guests
