It is currently Thu Nov 05, 2026 12:26 am
Vehicle: '95 lwb vitara
Post Posted: Tue Mar 15, 2011 6:17 am
If the column is locked, will it come out after unbolting the four firewall fastening bolts and the two torx head bolts?... mine isn't coming out. -__- any tricks to getting the fucker out? :D
Post Posted: Tue Mar 15, 2011 6:22 am
tried jiggling the column with the key in the ignition?
Post Posted: Tue Mar 15, 2011 6:30 am
When the world is dark and all else fails...
Stocker
Post Posted: Tue Mar 15, 2011 6:35 am
Ya can take the steering lock off by undoing the two bolts holding it.The heads are designed to break off.Use a small punch and bring them through enough to grab with visegrips.
bye
Post Posted: Tue Mar 15, 2011 6:52 am
bye
Bingo!!!! :D
Post Posted: Tue Mar 15, 2011 8:39 am
bye
Where abouts are these 2 bolts situated mate?
Cheers.
Post Posted: Tue Mar 15, 2011 8:49 am
On the ignition barrel mount
Post Posted: Tue Mar 15, 2011 9:18 am
Still can't find them. :( I have everything off but the ignition barrel. Any pics? I'm even looking on the new column and barrel and can't find any pins..
Post Posted: Tue Mar 15, 2011 9:21 am
They no longer look like bolt's, just domed head's..
Post Posted: Tue Mar 15, 2011 9:25 am
How do you undo them then?Cheers Stek
Post Posted: Tue Mar 15, 2011 9:32 am
Vice grips
Chisel and hammer
Drill
Post Posted: Tue Mar 15, 2011 9:42 am
bye
:D
Center punch a indent into it, then tap the punch with a hammer in the undo direction, undoing the headless bolt.. :P
Users browsing this forum: Google [Bot] and 223 guests
