It is currently Wed Apr 22, 2026 3:27 am
Post Posted: Tue Jul 15, 2008 8:10 pm
I've used big drill bits, and also ground off the spot welds with a grinder, both with varying success. I have to get remove the sill brackets (full of rust) and flares (virtual lift) at some stage, so I thought i'd get myself a spot weld drill bit. I justordered eBay, and got another 3 bits for it while i was there. The bits are double ended, so it's like having 8 bits all up. Cost me under $30.
Post Posted: Tue Jul 15, 2008 8:21 pm
never heard of it!
I just use a drill bit. Punch the cetre, then drill :P
Post Posted: Tue Jul 15, 2008 8:23 pm
never heard of it!
I've done that too, this thing is supposed to let you cut just th top layer of metal. I'll let you know how it goes though!
Post Posted: Tue Jul 15, 2008 8:24 pm
you can just grind the spot welds down, when you've ground far enough it breaks the join and you don't have a hole left in the panel to fill.
Don't worry, It's only a suzi...
http://www.auszo
Vehicle: 75 Cruiser
very technological there Damo.
If your sills are rusty right through then fair enough, but i used a grinder to remove my sill brackets, very carefully, so then i did not have any drill holes through the panels, so i didn't have to repair the drill holes.
Post Posted: Tue Jul 15, 2008 8:25 pm
they rock, especially on cars that all the panels are welded on
Post Posted: Tue Jul 15, 2008 8:26 pm
Jeez you guys are almost worse than my missus. Like I need an excuse to buy more tools :P :lol:
Post Posted: Tue Jul 15, 2008 8:34 pm
I might have to get you a bible, there goes all your money for the next 50 years :wink:
Post Posted: Tue Jul 15, 2008 8:49 pm
:x :x :x
I was looking one of these everywhere on the weekend. Ended up just using the angle grinder, was easier than I thought.
Would still like this for the flares. Got a link to the seller Damo??
Post Posted: Tue Jul 15, 2008 9:38 pm
I'll make some space on my bookshelf 8)
Post Posted: Tue Jul 15, 2008 9:40 pm
basketcase wrote:
:x :x :x
This is the mob I got it from ozmestore1
Post Posted: Wed Jul 16, 2008 1:45 am
I take it the centre pin is sprung and pushes up inside the bit. Just like a broach. I have seen normal twist drill bits machined / ground down to form a similar idea, like a timber spade bit also.
Post Posted: Mon Jul 21, 2008 9:37 pm
My mate got some of them from his snapon man when we removed the front clip from his gq, they worked great. Then we realised you can just grind blunt or broken drill bits the same way as the snapon ones n they work just as well without the $30 each price tag
ill try find a pic of the snapon ones
Post Posted: Mon Jul 21, 2008 10:58 pm
so how did it go damo you used it yet?
Post Posted: Tue Jul 22, 2008 12:29 am
you can also use a dowel drill, (used for timber dowel joints). there almost flat on the end with a littli spike in the centre, i think that is what the snapon ones are like to.
Post Posted: Sat Jul 26, 2008 12:21 am
I just ordered mine. Will hopefully get on to the flares with it.
Post Posted: Sat Jul 26, 2008 5:38 pm
You coulda used mine, and did my flares are the same time :mrgreen:
Post Posted: Sat Jul 26, 2008 11:20 pm
Very funny.
I think mine will not get used for a while. A lot of other things on the list to do before the virtual lift and that is not required till I get some 31/32's. But at least I'll have em there ready to go.
Post Posted: Sun Jul 27, 2008 1:14 pm
basketcase wrote:
Very funny.
That's what i said too!
Vehicle: sierra
Post Posted: Fri Sep 12, 2008 5:33 pm
Thats what we use at tafe and at nymans
Post Posted: Sat Sep 13, 2008 12:15 pm
i did my virtual lift last nite and i jus used a 5mm drill bit.. worked ok for me
Post Posted: Sat Sep 13, 2008 1:06 pm
Pics? Did you cut the guards or just move the flares up?
Vehicle: LJ20 LJ50
Post Posted: Sun Sep 14, 2008 10:00 pm
Hey Damo why didn't you use an easy out like you did once before as a hole enlarger?
Camels have nice toes
Post Posted: Mon Sep 15, 2008 12:15 am
:oops: 'tis true
And Brad will tell you that would be far from the stupidest thing I ever did :oops:
